Old 02-18-2010, 12:25 PM   #1
RMrider17
85 C10 Starter Problems
Hey, I have two problems with my truck its an '85 2wd long bed c10, with a 305/350
The first problem is that the starter will not catch the flexplate. I switched out the old flexplate thinking it had some bad teeth, and put it back togeather it started real nice maybe 20 times, and then started grinding again. Do I need to shim it? Or replace the starter gear maybe? or both?
The second problem is that suddenly my key wont turn to all the way to start, so i have to pull the linkage in the steering colum towards me to get it to crank. What do I need to do to fix this? Did it pop off? or do they randomly go bad or something?
Thanks any thoughts are appreciated
-Adam
RMrider17 is offline   Reply With Quote
Old 02-18-2010, 12:31 PM   #2
Tony@AirRideTech
Junior Member
Re: 85 C10 Starter Problems
-Adam
First I would make sure that the solenoid is engaging all the way....
Tony@AirRideTech is offline   Reply With Quote
Old 02-18-2010, 02:04 PM   #3
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
The problems are probably unrelated to each other. It sounds like the rack that pulls the switch rod is worn or the switch needs to be adjusted. If the old flex plate had bad teeth then so did the bendix, a bad bendix will quickly destroy a new flex plate. Fix one issue at the time and you will be okay. Good Luck. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-18-2010, 03:11 PM   #4
Matt Man
Matt Man's Avatar
Does the starter grind when you try to start it? if it does you need to put some shims on it to make sure it engages the flexplate. mine had this problem.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 02-19-2010, 08:20 PM   #5
RMrider17
Thanks for the help, the starter worked, it just was grinding, but Yeah we shimmed the starter following the guide you get with a new one. It took 3 shims on the one side. It would engage at some parts of the flexplate and than not others, but its all good now. I know the problems were unrelated I just figured I'd just put them both in one thread.
Ne way the one problem still remains, the key wont start it unless you pull the rod in the column towards you any thoughts?
-Adam
Old 02-19-2010, 08:44 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
check the top end of that bar and the pieces of metal it attaches to something is bent broke or worn
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-19-2010, 10:35 PM   #7
BigE77'
BigE77''s Avatar
I had the same problem a while back, the shims didnt fix it though, It might not be a bad idea to hit up a junk yard and find a bracket that go's from the back of the starter to the block if you dont already have one, it will hold the starter in the right spot.
77 Scottsdale,.454 .30 over, 10:1 flat top pistons, 480 lift comp cam, 781 heads stock valve size, some no name polished aluminumn dual plane intake advised by my machine shop to match the cam(He said is was great lol) Holley 750 vac sec, Turbo 400 built raybestos clutches and Kolene steels, Eaton Posi 3:73 14 bolt
BigE77' is offline   Reply With Quote
Old 02-20-2010, 05:17 PM   #8
RMrider17
Thanks old rusty, Ill check it out, I figured it might be something like that, maybe it popped out, and thanks big e, the shims fixed it though, for now
-Adam
Old 03-11-2010, 11:37 PM   #9
RMrider17
So, after all that it didn't actually get fixed. We pulled the valve covers on a hunch, and the engine has a head gasket leak into three cylinders, and was kicking the flexplate back because of all the coolant in the cylinders... SO Im getting a 350
-Adam
