02-18-2010, 01:15 PM | #1 |
71/72 Throttle pedal in 70
I want to put the 71/72 throttle pedal assembly in my '70 but don't know where to find one. Also would it be a pretty straight forward install? What exactly will I have to change and how long do you guys think it would take?
Thanks, Nova
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
02-18-2010, 01:27 PM | #2 |
Restoration Virgin!
Re: 71/72 Throttle pedal in 70
Hey Nova....
If you watch the parts board they are on there all the time.....BUT if you will become a subscribing member, you ca post up a WTB (Want to Buy) thread over in the parts board and I'm SURE someone can help you out. Second, member 'Rckcrl' makes an adapter plate with very little work to make it work in your 70.....I'll see if I can find his thread on it!!! Good luck!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-18-2010, 01:32 PM | #3 |
Between Trucks...
I used Rckcrln's adapter plate setup to put a '72 pedal in my '69. Worked out great, easy install. I used a Lokar throttle cable with mine, but you can use a stock '72 cable as well. Here's the link: http://67-72chevytrucks.com/vboard/s...d.php?t=371099
Beat it to fit, Paint it to match... Last edited by Sinister; 02-18-2010 at 01:34 PM. |
02-18-2010, 01:34 PM | #4 |
What did you do about the two balls that hold the original pedal in? Grind them off or what?
02-18-2010, 01:35 PM | #5 |
Between Trucks...
They unscrew from the floor. Then you can weld up the holes, I just left the holes cause I'm lazy.
Beat it to fit, Paint it to match... |
02-18-2010, 01:36 PM | #6 |
Restoration Virgin!
Thanks sinister....that's the thread I was looking for...."rokcrln" is the members name!!!...
02-18-2010, 01:50 PM | #7 |
Thanks a bunch. One more question, it says I only have to buy the 71/72 pedal and cable. Now is that the throttle assembly or just--
02-18-2010, 02:04 PM | #8 |
Restoration Virgin!
buy the whole throttle assembly....pedal, rod, bracket, cable....FYI...some guys are buying the Lokar cable...looks nice!!!
02-18-2010, 02:08 PM | #9 |
Between Trucks...
Yeah, you'll need the whole assembly. I don't think it's repopped, you'll need to hunt it down. I got the pedal assembly off a Board member for $20 or $30 bucks.
02-18-2010, 05:17 PM | #10 |
Let the hunt begin.
