Old 02-18-2010, 03:25 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Rear Bumper (Non step)
This might seem like a stupid question but, can the same rear bumper be used on Burbs, Blazers,and trucks? I am looking to replace the rear step bumper on my project, with the bumper off of a Blazer or Suburban.
Thanks,
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 02-18-2010, 03:38 PM   #2
raws67
raws67's Avatar
Re: Rear Bumper (Non step)
aftermarket book says fleetside/blazer/suburban so I would have to say yes.
raws67 is offline   Reply With Quote
Old 02-18-2010, 03:46 PM   #3
dv8customs
dv8customs's Avatar
I believe the bumper brackets are different for the non step version so if you get one you will need to grab the brackets as well.
dv8customs is offline   Reply With Quote
Old 02-18-2010, 04:05 PM   #4
ECU PIRATE
ECU PIRATE's Avatar
Thanks guys. One of the local yards (they pull the parts) has one for $ 75.00. I am going to check the pick and pull on Saturday for something cheaper. My truck originally had idiot lights and the PO added aftermarket gauges and screwep up all of the wiring. I am thinking about pulling a wire hareness and instrument cluster at the same time
The Fleet........
Old 02-18-2010, 09:38 PM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
You can use the blazer/burban bumper but you will only be able to use the outer brackets. I just recently did the same thing you are doing to your truck and it looks 1000X better than with the step bumper and mine is just driver quality.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-18-2010, 09:45 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
yes
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-07-2010, 11:21 PM   #7
lester622
So has anybody used the suburban brackets on a pickup?
I know the outside ones work but was not sure about the center ones, i only could get a set of brackets from a suburban because the pullapart yard here sets the trucks on rims and they put them under the back bumpers of every truck in the place.
lester622 is offline   Reply With Quote
Old 03-07-2010, 11:38 PM   #8
Cherub
Cherub's Avatar
center ones dont work.
Cherub is offline   Reply With Quote
Old 03-07-2010, 11:49 PM   #9
lester622
didnt think they did, thanks for the help
Old 03-07-2010, 11:50 PM   #10
flamingbig10
6.0 powered square
I'm using the center brackets from a burb on mine and using flat stock to bolt to the frame to the bracket
Aaron
Old 03-08-2010, 12:04 AM   #11
lester622
Cool, i think ima take that route, thought about that when i was looking at the center brackets. Thanks
Old 03-08-2010, 08:39 AM   #12
ECU PIRATE
ECU PIRATE's Avatar
I did manage to find that rear step bumper @ a pick and pull up in Maryland. Pulled it off of an 82' SWB. Bumper and all of the brackets for $ 43 bucks and some change (covered in another post I have on here)
The Fleet........
