Old 02-18-2010, 05:07 PM   #1
74 C-30
Dually Pride
74 C-30's Avatar
gauge questions
ok probably asked a million times but none the less
found a 73-74 parts truck, trying to get the gauge cluster as it has gauges and my 74 has idiot lights, whats involved in the swap? repin the connector i assume, any lines i need to run?
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 02-18-2010, 06:29 PM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: gauge questions
well it depends on if the it has the mechanical gauges or not. i bought a cluster out of a 76 for a 1980 that i had, and i couldn't use it cause i had the electric gauge set up instead of the mechanical gauge setup. but my guess is that you have mechanical gauges. make sure that you have the correct senders and i would rob the connector from the parts rig, which will make swapping clusters all the easier, and i would also use the bezel from the parts rig too. and if that one is to thrashed then i would start yard crawling. i've pulled quite a few nice bezels from trucks in different yards.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 02-18-2010, 07:00 PM   #3
Prong
Re: gauge questions
You'll need the oil line from the gauge to the block from the donor truck. I don't think the idiot light version would have a hard line, but I could be wrong. You'll also need the temp sender from a "gauge" truck. The idiot light version is different.
Prong is offline   Reply With Quote
Old 02-18-2010, 09:11 PM   #4
74 C-30
Dually Pride
74 C-30's Avatar
Re: gauge questions
ok thanks
when you say ' rob the connector from the parts rig' you are refering to the long narrow one that every thing plugs into, correct?
why do i need the bezel? are the holes different on the gauge bezel? truck has been picked over already so no bezel. it also still has the 73-74 grill on it, i want it, but i have no use for it....OH WAIT THE BRACKETS FOR THE GRILL! my buddy wants to buy it for the axles so i might get parts through him
'94 Ford Ranger
Old 02-18-2010, 10:50 PM   #5
60ratrod
yes, i do
60ratrod's Avatar
Re: gauge questions
yes. the idiot light bezel only has 2 holes in it, where as the gauge bezel has 6 holes for all the gauges and lights. and the connector i'm talking about is the one that plugs into the back of the cluster.
