Old 02-18-2010, 05:40 PM   #1
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
Tranny fluid change question
I kno everyone does things a little different, but im about to change my trans fluid and change the filter out on my truck on Sat, I was just wondering if you guys like to use the gasket? Ive heard some people dont use them and just silicone, then i ve heard some people use them with out silicone, so lets hear some suggestions guys!!!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 02-18-2010, 06:05 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: Tranny fluid change question
When i do mine i allways buy the AC Delco trany kit and i use the gasket dry no sealant.
If your trany is a 700R4 DO NOT USE ANY SEALANT! there is a small fluid return port very close to the pan lip and if it gets stopped up with sealant it will cause the trany to FAIL.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-18-2010, 06:08 PM   #3
camshaftgsxr
camshaftgsxr's Avatar
you just saved my butt thanks i'm doing one on a 700r4 and was wondering if i should or not
camshaftgsxr is offline   Reply With Quote
Old 02-18-2010, 06:13 PM   #4
60ratrod
yes, i do
60ratrod's Avatar
no matter what year of tranny i'm changing the fluid and filter of i never ever ever use silicon to seal the pan. i always use the gasket. i prefer the rubber type. that way if i ever have to drop the pan again i don't have to fight the gasket to get it scrapped off.
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 02-18-2010, 06:19 PM   #5
Mr.Scary
Mr.Scary's Avatar
thats another good question, rubber? or cork?
Old 02-18-2010, 06:30 PM   #6
camshaftgsxr
rubber they don't have to be scraped off after they're hot like the cork, unless you leave them on for a year...or ten..... shame, shame, shame
Old 02-18-2010, 07:33 PM   #7
3r!c84
Badass
3r!c84's Avatar
also check the pan it self,it might be worped from over tighting the bolts.put a straight edge on there and check that and your good
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-18-2010, 08:18 PM   #8
87 STEPPER
87 STEPPER's Avatar
Thumbs up Re: Tranny fluid change question
This is why i use only AC DELCO trans kit's the gasket that comes in them looks sorta like cork but it's got some sorta coating on it and they never need sealant and they never leak.Oh and they just peel right off the next time you chng your oil.
As mentioned befor just dont over torque the bolts and ck the pan lip for trueness.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 02-19-2010, 10:20 AM   #9
Mr.Scary
Mr.Scary's Avatar
hey 87 stepper ive never seen this AC trans kit before where can you get it from, i was just gonna use fram from o'reillys
Old 02-19-2010, 10:52 AM   #10
mhicks
mhicks's Avatar
The torque converter will still have the old fluid in it when you drop the pan. The quick change oil places can pump it all out (tranny and torque converter) in reverse (which back flushes the filter) and you never have to take the pan off.
mhicks is offline   Reply With Quote
Old 02-19-2010, 11:09 AM   #11
68Timber
I know the pieces fit
68Timber's Avatar
I've had trouble with the rubber gaskets leaking. If you use cork and tighten the bolts the the spec'd 12 ft/lbs you'll be good to go. You have to crush that rubber gasket a little more to keep it from leaking, I had to step it up to 25 ft/lbs but that stopped the leak.
I've used both types, I've never used any silicone. I've always used the NAPA kit.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-19-2010, 03:14 PM   #12
60ratrod
yes, i do
60ratrod's Avatar
well i find that its always a good idea to remove the pan and check/replace the filter. i've dropped a couple pans that didn't leak to either find the filter is either collapsed/busted or laying in the bottom of the pan(last 2 th350's actually). so i would go a head and change out the gasket and filter then take it in to have the tranny flushed all the way
Old 02-19-2010, 03:48 PM   #13
87 STEPPER
87 STEPPER's Avatar
I get it at a autopart store here called Bennett auto supply but there a Florida base store but any auto parts store that handels the AC Delco line should have them i allways specify AC Delco
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 02-19-2010, 04:56 PM   #14
Mr.Scary
Mr.Scary's Avatar
All great answers!!! Im getting ready to change the fluid and filter tomorrow so I just wanted to see how some of you guys are doing it. unfortunatley I could not find the AC Delco trans filter and gasket kit here in texas so i had to go with the kit that o'reillys carrys and im used to the cork gaskets and have never used the rubber ones before, and this kit i just pick up had the rubber one in it so i guess ill just give that one a try and hope for the best.
