02-18-2010, 10:50 PM | #1 |
Strippin' paint
Worked for about 3 hours today with a DA and 80 grit and only got about 80% of one rear quarter done. There has got to be a better way. What do you guy's suggest?
Thanks! |
02-18-2010, 11:07 PM | #2 |
Re: Strippin' paint
aircraft stripper
02-18-2010, 11:11 PM | #3 |
Re: Strippin' paint
a electric drill with q wire brush atachment and a grinder with a wire wheel worked great for me. This method will remove body filler be aware. This mothod will take it all the way to the bone.
jared |
02-18-2010, 11:33 PM | #4 |
Robert Olson Transport
Re: Strippin' paint
im gonna send this to the appropriate section for ya
02-18-2010, 11:53 PM | #5 |
True Addiction
Re: Strippin' paint
I went to Home Depot, because I frequently do. Pick up some Klean Strip KS-Premium. It honestly worked really well for me. I was able to strip both doors in one night. Good Luck
RCC |
02-19-2010, 12:39 AM | #6 |
Re: Strippin' paint
i agree with the aircraft! before you put it on, scratch the paint, it will let the aircraft dig into and under the paint! be sure to use THICK gloves goggles and a GOOD respirator!
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
02-19-2010, 10:55 AM | #7 |
Re: Strippin' paint
I used a Harbor freight/Eastwood Co. sandblaster on all my panels, inside and out. I've always heard this should never be done because of the possibility of warping the sheetmetal.
Well, they must be talking about the big industrial sandblasters, because I couldn't produce enough heat if I tried. The summer sun heats the sheetmetal 100x more! It worked very well, IMO. |
02-19-2010, 11:03 AM | #8 |
Re: Strippin' paint
If you have a mud hog or DA use 40-60 grit to scratch it up real good, apply the stripper in 2-3 ft areas cover with saran wrap or similar plastic wrap this keeps the solvents from evaporating to quickly after letting it soak 1/2 hour maybe less depending on brand of stripper remove the plastic wrap scrape off you may need to reapply to remove it all but I've found this method works the best for me.
02-19-2010, 12:21 PM | #9 |
Re: Strippin' paint
Stripper?! Don't we all love stripper....Oh that might be something else I was thinking of.
02-19-2010, 08:38 PM | #10 |
Re: Strippin' paint
I tried a DA sander also...I gave up quickly with that. I ended up buying some Clean and strip disc's for my angle grinder.
They worked well but keep them moving to avoid heat build up. Used the same to strip my hood and doors. I still sent my stuff to the sandblasters to get the area's that could not be stripped with the disc's. |
02-20-2010, 11:44 AM | #11 |
Re: Strippin' paint
Thanks for the suggestions guys. I have the bed done but I will try some of your methods on the cab and front end. This DA is just to slow!
02-20-2010, 01:10 PM | #12 |
Re: Strippin' paint
Aircraft stripper is definately the easy way to go. It is harsh on the paint and you. It will burn your skin so be careful but it easily takes multiple layers of paint off and quickly.Buy some disposable scrapers because the paint/stripper mix hardens like a rock.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-22-2010, 03:48 AM | #13 |
Re: Strippin' paint
I have recently been stripping my truck bed down and the easiest way I have came across is to use an 10" Wire wheel on a Air Grinder and it has stripped off all the way to bare metal in no time.. I have one side of the bed stripped down inside and out in one night. The trick to using this wire wheel is after time flipping it over and creating the wires to move the other direction. also This wire wheel has not caused me any problems due to heat or scratching of the metal at all. but do remember to wear safety glasses incase the wire goes flying off.
02-22-2010, 09:07 PM | #14 |
Re: Strippin' paint
Sandblasting was the quickest way for me...but you gotta have a decent compressor(at least 60 gal) i hung plastic around the carport to contain the mess.
02-23-2010, 04:01 AM | #15 |
Re: Strippin' paint
Aircraft stripper is pretty much the best on the market, if you don't mind the smell.
