View Poll Results: Keep the really nice C20 suspension or clean up the C10? | |||
C20 to C10 drop spindles are the way to go |
1 | 33.33% |
C10 will be easier/cheaper in the long run |
2 | 66.67% |
Voters: 3. You may not vote on this poll |
C20 to C10 drop spindles or entire C10 frontend?
I have a real dilemma here.
I have a C10 front suspension with all new (uninstalled) ball joints, rod ends, A-Arm shafts, etc.. I also have the stock frontend on my C20. So here's the problem: I crawled under the two trucks and the C20 looks just amazing. The frame still has the original paint on it, the crossmember is not caked with grime AT ALL, the A-Arms look really clean. The only real concern that I have is the steering stabilizer with lines going into it from the PS pump, but I'm thinking I can probably just nix the whole stabilizer setup. The C10 frontend is caked with crap but I'm sure the crossmember and control arms are structurally alright. So what would you do? I feel like it would be a waste to junk such a nicely aged setup, but at the same time the drop spindles cost more. Do C-20 suspension/steering parts cost more in general?
1968 LWB C20 / AC / Wood Bed |
Happy to be here
![]() Join Date: Mar 2000
Re: C20 to C10 drop spindles or entire C10 frontend?
Lets assume that your 68 has never been rebuilt. Those parts are 42 years old right now. Unless they have been sitting on a shelf out of the weather, I'm not much on 42 year old parts.
Since you have the parts to rebuild the C-10 suspension, why not clean it up and slide it in all fresh and NEW... ![]()
#3 | ||
A true "stabilizer" is just a "shock absorber" that has an equally balanced push/pull rate. You cannot "just nix" the cylinder w/o changing the steering box too. A power steering system is much harder to steer when the power is gone. The "power assist" is not as bad, but it would still be difficult to drive that way.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#4 | |
Junior Member
This is easy....... are building a 3/4 ton truck or a 1/2 truck? You will get a much better selection of wheels with a 5 lug circle than you will with a 6 or 8 lug circle. If it were me and I were building a driver that was not going to be 3/4 ton tow pig... I would build it with the 1/2 ton components because they are there and they are new and you get a better selection of wheels with a 5x5
#6 | |
