Frame Split
I am installing a new rear housing assembly. On the far rear of the frame, both of the spot welds have broken. Can I stabilize the frame with bolts, or should I have it re-welded? Much easier to bolt. I don't tow, so that shouldn't be an issue. I haul about 1,000 # once a year, (mulch in the spring). First one I've seen break.
Thanks for your thoughts, TF |
Fabricate till you "puke"
The crossmembers should have rivets in them, I dont recall any welds. You can knock the rivets out, & use a grade 5 or 8 bolt, with pinchloc nuts(no lockwashers), they tend to split & fall out over time. The snugger the bolt fits the hole, the better. Good luck...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Frame Split
This is not in the cross menber area. It is all the way at the rear of the frame, aft of where the housing bolts on with the U bolts. There are two spot welds where the two sides of the frame rails meet the the far rear of the frame. TF
would that be on the trailing arms?
Formerly yellow72custom
I am also thinking that it is the trailing arms you are talking about. If the spot welds broke, i would either weld them back up, or go to the salvage yard and get a replacement trailing arm.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Yes, it's the trailing arm on the drivers side. The factory had a spot weld where the two halves meet. I'd like to try a bolt if you think it would work for a temporary fix. TF
Those arms tend to get rust between them, & open up. You might try a bolt to pull them together, but it probably wouldnt be a bad idea to run a bead of weld down the vertical groove on the back end of the arm to make sure that it doesnt separate. Good luck...crazyL
You're right, there is a small amount of rust between the two pieces. I can bring it back together and align, and bolt. I have already removed the rsut and coated. If you think it will be OK for a limited hundreds of miles I can get it welded. At least I can get it operational. Thanks for your help. TF
I would give it a try, just keep an eye on it that it doesnt separate & let the U bolt loose....crazyL
