02-19-2010, 12:05 AM | #1 |
the pollock
PICKS OF YOUR HIGHLIFT jack
hey all,
Im ready to get off my arse and mount up in a lockable manner my highlift jack. Im not really willing to leave it ever again in the bed and it's a beast to get into my toolbox. can i please see you picts of mounts? plllleeeeaaaasssseeeeeeeee... thanks!
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
02-19-2010, 12:30 AM | #2 |
Resident of Here
Re: PICKS OF YOUR HIGHLIFT jack
How is it a hassle to get it into the toolbox?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
02-19-2010, 12:35 AM | #3 |
not mines but its in the thread near the botom of this page titled jacks. Looks like a good set up.
Well I read again and it says not ready to leave in bed. So do you want it hidden under the bed? Or behind the seat maybe, if possible unless you have speakers or the seat doesn't fold.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 02-19-2010 at 12:40 AM. |
02-19-2010, 09:40 AM | #4 |
the pollock
no i meant as in just "chuck it" into the bed unsecured..
if i can bolt it and lock it im happy with the mount. nd tito... it's a hassle because my toolbox is above my eyelevel on my truck with a split lid box.
02-19-2010, 10:41 AM | #5 |
I monted mine useing wing nuts and bolt welded to my gate:
I tap them tight with a hammer. you can see the back of the mount I made. Works Great!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
02-19-2010, 01:56 PM | #6 |
Registerd User
I like your set up. I'd like to do something like that.
02-19-2010, 08:40 PM | #7 |
the pollock
burt i'll be talking to you when i get off me butt and make that style of gate..
ONLYIFIHADACHEVY.. did you buy those brackets where from? thanks!
02-19-2010, 09:45 PM | #8 |
How is it not a hassle?Are you serious?
I don`t have mine mounted.I used to on another truck.I mounted it along the top bed rail inside.
02-19-2010, 09:59 PM | #9 |
Resident of Here
Well, you just grab it and out it in. Its not like it weighs #400.
02-19-2010, 10:02 PM | #10 |
Its not mine, it's mudder's, in the thread titled jacks. Pm him. And it looks like he bought them by the stickers on them.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
02-19-2010, 10:19 PM | #11 |
User #12137
02-19-2010, 10:21 PM | #12 |
the pollock
sahweeet yall rock!
keep a simpleton working on a big old truck wheee!
02-19-2010, 11:40 PM | #13 |
I think I got them from Rocky Mountain Suspensions.
02-19-2010, 11:46 PM | #14 |
User #12137
i got about the same set up that mudder has but mounted it inside quarter panel on a 78 blazer , got it from my local, tractor supply store
02-20-2010, 12:39 AM | #15 |
the pollock
http://cgi.ebay.com/ebaymotors/ws/eB...d=120504678274
that's what i was loooking for hey tito... dont argue it's a serious PITA when your toolbox is above your head.. you'll understand when you get older.
02-20-2010, 11:46 AM | #16 |
Not sure where the pics are anymore, but will try to describe how I mounted mine in my 70 long bed truck.
On the drivers side at the rear stake pocket I made a bracket. The bracket was a piece of 2" wide 1/8" angle about 4" long. In the middle of the piece of angle I put a 1/2" bolt that had a smooth shank and I cut the head off. I then drilled smaller holes near the ends of the metal for 3/8" bolts. I bolted the whole thing to the bed with the bolt facing forward. Then on the middle stack pocket, I drilled a 1/2" hole and made a similar double nutted bolt with the head cut off and a hole drilled in the end for a lock or hitch pin. This pin pointed to the passengers side of the bed. You put the foot of the jack on the "pin" at the rear of the bed, then you put the beam of the jack on the second pin. I put a piece of rubber behind the beam to protect the bed and reduce rattling and a bicycle inner tube over the jack handle for the same reason. I used a spring behind the hitch pin or lock between the beam to hold it tight. Clear as mud? Very few parts were required and it kept the jack out of the way, below the bed rails, easily accessed, yet mostly protected from theft.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 02-20-2010 at 11:47 AM. Reason: 3/8 bolts NOT 3/4... |
