Old 02-19-2010, 12:17 AM   #1
Leviticus
Shake and Bake!
Leviticus's Avatar
What Radiator Hoses For A Serpentine Conversion? Need To Get Them ASAP.
Hey guys,
I am in the middle of a serpentine conversion and all is going well except my lower radiator hose won't fit right with the passenger side bracket in place. The bracket pushes the hose down onto the frame rail kinking it.
I am pretty sure I am going to need a new upper hose as well due to the alternator location. I bought a straight thermostat housing instead of the angled one, haven't opened it cause I am not sure I will need it.
What year vehicle have you guys gotten radiator hoses for to make them work? Some people seem to have had no problem with this, but some say to get new hoses??
Thanks guys!
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 02-19-2010, 01:00 AM   #2
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: What Radiator Hoses For A Serpentine Conversion? Need To Get Them ASAP.
bump
Thomas Jefferson
Old 02-19-2010, 01:12 AM   #3
GASWAGON
AMERICAN IRON ADDICT
I just used the cool flex copper flex pipe on my friends 427 with the Gm serpentine system and it worked great! Not cheap but worked great!
GASWAGON is offline   Reply With Quote
Old 02-19-2010, 01:36 PM   #4
Leviticus
Shake and Bake!
Leviticus's Avatar
Bump,
Anybody have any ideas on that year 350 truck to get a hose off of? I need the upper and lower. Just trying to save myself from having a new collection of useless hoses lol.
Thomas Jefferson
Old 02-19-2010, 02:25 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
When I was searching for an alternator, checked out one for an '87 Chevy PU with a 350 that had the pulley for a serpentine setup. IIRC
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-19-2010, 03:35 PM   #6
sdailey
The Few, The Proud
sdailey's Avatar
Try this one....
http://67-72chevytrucks.com/vboard/s...d.php?t=346154
Shannon
sdailey is offline   Reply With Quote
Old 02-19-2010, 04:55 PM   #7
combustion
Originally Posted by sdailey View Post
"I went to auto zone and they let me look through their hoses. the number on the hose was xl 1171. I had to cut it about 2 inches but it will work and look good."
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 02-19-2010, 09:00 PM   #8
Leviticus
Shake and Bake!
Leviticus's Avatar
Thanks for the help guys, I found upper and lower hoses that will work with some trial and error. Everything is almost finished, just need to refill the coolant and power steering tomorrow, check for leaks, re-torque all my bolts and I should be on the road, Woot woot!
Thomas Jefferson
Old 02-20-2010, 10:29 AM   #9
mrein3
mrein3's Avatar
Please post part numbers for those hoses and/or what they fit.
Some of these "modern" auto parts store jockeys are paralyzed unless you give them a vehicle spec.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
