Old 01-31-2003, 08:20 PM   #1
Purs
Got Big Block?
Purs's Avatar
SWB Big Block Truck
I found a guy that has what looks like a '72 SWB Fleet with a 402. He says it's the original 400. Is there a way to tell from the vin number if the tag is not on the glovebox door? Also, the rear view mirror attaches like a 71 from the top of the cab...? I may be able to pick it up but don't want to overpay. thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 01-31-2003, 08:27 PM   #2
ckhd
ckhd's Avatar
The VIN will only tell you that it is a V8. Look for emission stickers on the inner fender and the radiator support.
Look at the stamping code and post it. We should be able to tell you at least if the block was original to a '71 pickup (post the VIN too so that we can decode that for you too). I think the stamping on a BB is the same as a SB - on the front of the block, on the same surface the head would bolt to on the passenger side. It will have a code like T0625TMD or something.
Getting the casting numbers off the back (on the webbing where it bolts to the tranny on the driver's side).
Look for a build sheet in the back of the seat too.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 01-31-2003, 08:54 PM   #3
JimKshortstep4x4
Talking
A couple of things to look at:
Big block engine mounts were different in 72 from the 71,
(motor mounts are like the later style and the towers are very different)
Original big block trucks should have a tin shield screwed to the cab on the passenger side as an exhaust shield.
Look closer at the mirror where it is mounted on the cab. The 71 cab will have a raised hump for the mirror and the 72 will not. Some guys got tired of the glued on mirrors and screwed the earlier style on.
Good luck!
Jim
Old 01-31-2003, 11:34 PM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
The serial number that is stamped on the block (pad is located in the front of the passenger side head) should match the VIN tag serial number and the frame stamping as well. Take a look at this:
http://67-72chevytrucks.com/Chevyear.html
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 02-01-2003, 01:02 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Here is the raised pad Jim was refering to. On the '70 and older there was no raised portion. I kinda wonder if it isn't a truck slapped together. (Always skeptical)
Also, if an original big block, it'll have a remote mounted power steering resivour...at least, if equipped with power steering.
Old 02-01-2003, 12:24 PM   #6
Downtown
Downtown's Avatar
Cool
If the cab was a big block cab, it will have a high hump. You can also check to see if the VIN on the cab matches the one on the frame. The VIN is on the frame on top of the frame just behind the steering box and in front of the motor.
72 Shortbed fleetside 402 BB, AC, Posi
72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new
66 Chevy Caprice 2 dr
74 Honda CB750
New Palestine, IN
Downtown is offline   Reply With Quote
Old 02-01-2003, 01:43 PM   #7
Purs
Got Big Block?
Purs's Avatar
the cab is a high hump, I will look for the remote power steering res. thanks for the responses.
