02-19-2010, 01:49 AM | #1 |
ripping out my rocker
So i just tore into my first repair on the new truck... on any truck. Here are some pics in case you see something i need to change/fix. I am wondering if i need to add some metal to the floor section right where the rocker meets it. Just where it curves down then back out towards the door. I'm sure i do cause there is nothing to weld to. Until i get the whole rocker and backing plate out i cant visualize how much i will need to add, and how far to the front the rust goes. So this post will probably take a while to unfold because i can only work on it a couple of hours a day for a while. Oh and yes that is spray foam.
j. |
02-19-2010, 01:56 AM | #2 |
Re: ripping out my rocker
Yeap you definitely need to replace the section of floorboard. I believe they make just that section for this repair.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
02-19-2010, 09:21 AM | #3 |
Who needs sleep...
I have the same areas to repair, I've been eyeing a $220 set from Ecklers http://www.ecklerstrucks.com/chevy-t...1967-1972.html and http://www.ecklerstrucks.com/chevy-t...1967-1972.html and http://www.ecklerstrucks.com/chevy-t...1967-1972.html
haven't bought them yet, I was going to post about them soon to see if anyone had any thoughts... seems like a good deal to me. Trip |
02-19-2010, 10:23 AM | #4 |
Restoration Virgin!
Hey Guys,
Ahhh yes....it's time to change out those rusty rockers Why not talk to some of our Board Vendors....they may be able to help you out with better pricing...and for sure better customer service!!!....Click on the link in my signature, or check out the vendor marketplace over in the parts board.... Good luck!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-19-2010, 01:03 PM | #5 |
I just completed the same job on my 72 Chev.. I sectioned the floor boards and cut the spot welds on the Rockers. The total install was done with Body Epoxy. I can MIG weld but the Epoxy made for a very clean tight install. Not to mention the overall convenience. Al W.
02-19-2010, 01:17 PM | #6 |
Car Knocker
Been there, still got one more side to do. Here is how far I had to cut mine. I agree, use the board Venders.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. Last edited by jay6891; 02-19-2010 at 01:21 PM. |
02-19-2010, 07:12 PM | #7 | |
Not a bad price but its still $50.00 higher than our prices We are $172.00 plus shipping |
02-19-2010, 07:25 PM | #8 |
Redefining LowBudget
check my build ..look for the crappy pics
I did the same repair that mike is tackling I also did cab supports..all I can say is if your goig to open it up that much be sure to secure the cab from front to back so your door opening doesn't get wider..also support it from falling try to do all your work with out moving it around ( or at least get the flor section back in) the floor pan I bought came in 2 pieces one for under you feet that goes all the way to the tunnel and one that started about 2 or 3" under the seat...these 2 panels will make the inner rocker then add the rocker and you should be buttoned up tight....all I can is say trim fit trim fit trim fit Not a bad prject but plan on 1 full day and part of another..also yur going to need a tube of seam sealer once your done
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
02-20-2010, 01:26 AM | #9 | |
Who needs sleep...
Trip |
02-20-2010, 09:13 AM | #10 |
CAN'T FIX NOTHIN
my 67 had a rust spot right in the floor area next to the rocker , my inner rocker's were perfect and passenger side did not have anything just the one spot in this pic , I made a patch and welded it in on mine , but I would buy those pre made floor patch's if I were you it will make a better job ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
02-20-2010, 09:20 AM | #11 |
CAN'T FIX NOTHIN
be sure to get then inner rocker panel too it give support to the outer rocker skin , mine had surface rust all over it I cleaned mine with a wire brush and painted them ,,,,
02-20-2010, 10:36 AM | #12 | ||
"I ain't nobody, dork."
I'm not lookin' forward to doin' mine. But it needs to be done in my '72. Rust is one of those projects/repairs that can appear to be "easy" until you start cuttin'. Then it can be a can o' worms. Always more than you bargained for.
Rust never sleeps... Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-20-2010, 01:48 PM | #13 |
Suddenly I feel very fortunate to have purchase trucks with no rust.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
02-20-2010, 03:45 PM | #14 |
Not really that hard -- just take your time and get all the rust out. I had rust on the rear and front door pillars, inner and outer rockers, cab corners -- and rear cab supports! Not to include the rusted out area around the windshield! Bought patch panels, fabriacted some of my own patch panels, and cut and welded in new as requiired.
Probably would have been easier to find a better cab (I live in AZ) but i've had the truck 21 years -- son came home from the hospital when he was a baby (13 years ago) -- etc. Lots of good years in there too and it wouldn't be the same with a different cab. Also, by the time I was finished with this I had improved my fabrication skills and everything else i am doing now (filling gas door hole, capping off stepside bed ends and stake pockets) seems so much more fun and easy!!! |
02-20-2010, 11:31 PM | #15 |
I agree at what point is it not the same truck...I think the cab is its sole...you can give it a new heart a new set of sneakers or even a new outfit but the cab is what makes it what it is...
02-21-2010, 09:45 AM | #16 |
well both front and rear cab supports are gone. and i have the replacements for those. also i have the replacements for the inner and outer rocker panels. the front piller looks ok but the rear one is not there. everything was held together by spray foam. can i replace it without replacing the cab corner? cause it is still good.
