02-19-2010, 04:19 AM | #1 |
Installing a different size rearend
Hi i got a rearend i want to get to work with trailing arms its a different diameter than the regular 3 in does any one make a kit for this has anyone done this
70 SWB STEPSIDE 70 BLAZER 09 challenger |
02-19-2010, 07:45 AM | #2 |
67-72 parts collector,…
Re: Installing a different size rearend
The only one I know is ECE's trailing arm mount. I wonder if you could modify them to work?
02-19-2010, 10:31 AM | #3 |
vw guy & now c-10 guy
you're talking about the weld-on perches, right? I think CPP sells them in different diameters for different rear ends- I could be wrong though- check out their website.
OK, I looked at their website- they do have them-BUT only show them for 3" axle tubes- so maybe contact Jeff and see if they can make you something? Last edited by Mike J; 02-19-2010 at 10:38 AM. Reason: more info found |
02-19-2010, 10:50 AM | #4 |
Yeah right now i just wana be able to bolt the rear up
02-19-2010, 11:52 AM | #5 |
Junior Member
Dont forget about the panhard bar which the factory rear end has a bung cast onto the houseing.... you can always go to a weld on panhard bar but it has to be in there. If you are going to a different 10 bolt or 12 bolt, we do have a panhard bar bracket that relocates the bar further down to correct its positioning for a lowered ride height. The axle brackets are gravey... you could even get in touch with Mosier for some replacments to weld onto a different rear end.
02-20-2010, 03:06 AM | #6 |
Thanks alot ill check with them
