Old 02-19-2010, 04:52 PM   #1
SkylineNXS
SkylineNXS's Avatar
2000 sierra 4wd rear posi question
so yesterday i was pullin away from the curb in 2wd and the right side rear was sittin in a buch a snow, and it just sat there spinnin. Trucks got about 87k on it i think, do these posi units give out or somethin? couldnt get the truck to move, had to put it in 4 wheel. any thoughts?
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 02-19-2010, 05:07 PM   #2
V30 mongo
Re: 2000 sierra 4wd rear posi question
First off does it have the G80 option. Check the sticker in the glove box. Or if you got it used maybe the rear was changed at some time. It is possible that it needs a fluid change to "clean out" the clutch packs. The Eaton type of diffrential does have clutch packs and a lot of little parts that can get "gummed up"
V30 mongo is offline   Reply With Quote
Old 02-19-2010, 06:46 PM   #3
SkylineNXS
SkylineNXS's Avatar
Ok thanks, ill check the code, and my dad bought it new and then i bought it off him, so i kno the diff has never been touched. Ill check the code and get back.....
thanks again
brad
Old 02-20-2010, 02:11 AM   #4
SkylineNXS
SkylineNXS's Avatar
So i do have the G80 option, so im gonna try and see if its the fluid. Whats the easiest way to change it? do i have to remove the pumkin cover like on the older trucks?
Brad
Old 02-20-2010, 08:06 AM   #5
truckdude239
truckdude239's Avatar
yes. but remember just because you have posi doesn't mean your not going to get stuck. if you change the fuild please go to gm and get the fuild and special additave for the posi rear ends
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-20-2010, 09:13 AM   #6
Gray Ghost
Gray Ghost's Avatar
Doesn't sound right for a failure at 87k. You have a locker rear axle....should have gotten the traction to both wheels equally, was the other wheel on dry pavement?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 02-20-2010, 04:02 PM   #7
SkylineNXS
SkylineNXS's Avatar
Well im not saying i wont get stuck, but like gray ghost asked, yes the other tire was on dry pavement, and was not moving at all, i was watching it while the other was just sitting there spinning....I would most likely get the service done at the dealer as i have never really done anything on rear ends before...
Old 02-20-2010, 04:07 PM   #8
msgross
msgross's Avatar
It's easy to change the fluid...pull the cover, use black RTV for a new seal... there will be one fill plug that gets removed and filled back up to that line...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-20-2010, 05:23 PM   #9
Gray Ghost
Gray Ghost's Avatar
I just thought about the fact that your G80 might be a limited slip. You can tell the difference...the locker makes a noise and a clunk when it locks up, limited slip is usually very quiet. If you had a limited slip there's probably nothing wrong with it....you were just stuck.
Kelly
Old 02-20-2010, 05:54 PM   #10
SkylineNXS
SkylineNXS's Avatar
Hm weird, i also tried it in my driveway quick, which had snow on both rear tires, and still only one went, but it did switch sides in the beginning, so i guess it is still kinda workin, haha.
Brad
Old 02-21-2010, 08:49 PM   #11
Benelli
Watchin the rust grow
Benelli's Avatar
Sounds like a limited slip if it changed.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-22-2010, 02:00 PM   #12
SkylineNXS
SkylineNXS's Avatar
ok cool, so is there any other way i can tell if its a limited or a locker without takin off the diff cover?
Old 02-22-2010, 04:36 PM   #13
truckdude239
call the delaer and have them run the vin number they should be able to tell you whats in there
David fuller
2012 Subura outback
1999 honda accord
Old 02-22-2010, 05:10 PM   #14
Gray Ghost
Gray Ghost's Avatar
Let us know what you find out.
Kelly
Old 02-22-2010, 05:15 PM   #15
SkylineNXS
SkylineNXS's Avatar
Will do, thanks guys.
