Old 02-19-2010, 07:25 PM   #1
grs
Bleeding brakes
How do you bleed Wilwood Calipers? They are 4 piston calipers. Two of the bleeders are on the bottom of the calipers. The master was bleed, but the truck does not want to stop very well. Every thing is new. Thanks for your help.
grs is offline   Reply With Quote
Old 02-19-2010, 08:29 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Bleeding brakes
Take the calipers off the rotor, flip them upside down, open the bleeders and let the air and some fluid flow out. Gravity will do the bleeding for you.
After the air is out and you're getting clear fluid, close the bleeder and reinstall the caliper.
