Old 02-19-2010, 09:40 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Help Factory Truck Stance Question!!!
According to LMC a truck with stock suspension should measure 32" from the ground to the top of the wheel arch. My dad's truck measures 27" and he does not have dropped spindles. Is it possible to purchase 4" lowered springs? Or could there be another issue that we are not seeing?
1971ChevyTruck is offline   Reply With Quote
Old 02-20-2010, 09:52 AM   #2
1971ChevyTruck
Re: Help Factory Truck Stance Question!!!
ttt
Old 02-20-2010, 10:07 AM   #3
clay68c10
clay68c10's Avatar
A shorter tire would do that. Also the springs loose height over time. The more accurate measurement would be from the center of the spindle hub to the wheel opening, but I'm not sure if anyone has that.
Early Classic Enterprises has a nice set of pics of trucks at various ride heights. There's a few pages.
http://www.earlyclassic.com/tech.asp...tance%20Photos
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-20-2010, 10:10 AM   #4
big_al_71
big_al_71's Avatar
there could be a two inch, a one inch, a three inch who knows spring that was cut. I think your best bet is to go ahead a measure a factory height spring or ask here if someone has that measurement then measure your dads truck spring and that will give you an idea. I lowered my truck four inches Uusing a spring and spindle comboand with an 18 inch wheel it is right at 27 1/2 inches from the floor to the fender lip.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-20-2010, 10:21 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
When I took the stock 16" steel rims off my truck for 15" mag wheels and 60 series BFG Radial T/A's... mine dropped almost 3" - 4" from stock at the fender well with just tires and wheels alone. I am going to go lower this spring/summer. But for now, the suspension is bone stock.
Lots of different variables from "stock" height from the factory... even rear spring packages from the factory had rear ends higher or lower depending on the setup. I think LMC is using the 32" as just a guideline/baseline.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
