53 chevy 3/4T Chassis
Can someone tell me the what the difference is in the lenght of a 3/4T Vs. the 1/2T frame?
I measured the front and rear width and the front is the same but the rear is 43" wide so not much taper at the rear. I want to place a 1/2T (53) bed on the long wheel base frame what problems am I going to have with the cab, core support, and the rear box? I know I will need longer running boards and short aprons for the short bed. CAn someone tell me what I am missing!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Cancer Survivor in the making.
Re: 53 chevy 3/4T Chassis
The overall length of a '53 1/2-ton is 191-1/4 inches with a wheelbase of 116.
3100 dimensions The overall length of a '53 3/4-ton is 200-3/16 with a wheelbase of 124-1/4. 3600 dimensions Are those the numbers you are looking for? |
Thanks Steve, that helps alot.
It looks like everything will fit but the rear width of the frame, which brings up the spring mounts which are removed along with the rear end. I will have to sleep on it some more
#4 | |
Registered Chevy Owner
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
The section we added to the body is 10" I think we can cheat 3/4" in the rear mount and add a crossmember to the rear of the chassis to match the 1/2T bed rear crossmember
Sounds like a good play to me
AD Addict
I've got a 3/4 ton naked frame if there is anything you need "looked at."
I could mock up a box on it but you are right about the springs on the 3/4 ton being on the outside of the frame. It can't be that hard to put 1/2 ton springs under it or just use some "modern" springs from an S10 or 1500 truck. Those old springs are for a torque tube anyway so it might be better for lateral control to go with updated springs. |
AD Addict
Just curious, how are you mounting your cab in the rear? Are you staying with the shackles or are you putting mount pads in like the front? Or is your cab old enough that it didn't have shackles to start with?
#9 | |
Yes that is where we are at in the moch up stage. I am trying to justify spending money on another frame (3/4) or using the 1/2T we have and add 10" to the middle under the cab. The cab is a 53 so there are shackles on the rear. Looking for all the challenges before we get any deeper in the build
#10 | |
How does the 3/4T box mount at the rear to the frame?
Same as a 1/2-ton. A couple of ears on the cross sill with bolts through them into the frame.
Funny thing is just Sunday I looked at two '54 Chevy pickups, a 1/2-ton and then a 3/4-ton both with all the bed wood removed. Part of the purpose was to show a buddy exactly what is the same and what is different.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
AD Addict
I'm just wondering if you need to do any floor stiffening where the shackles are. Not sure how the weight distribution changes with your 10" addition. That's why I was thinking of a second set of "front" mounts for the rear or even what some of the S10 guys are using back there.
#13 | |
We did talk about a strengthing rib under the splice on the floor but not about a additional body support. Thanks What do the S-10 mounts look like?
#14 | |
#15 | |
I looked it up in the LMC Truck catalog online and they show two different parts for 1/2- and 3/4-ton.
#16 |
glad u asked, I needed these dimensions too! Just not yet, but down the road.
[CENTER][FONT="Arial Black"]-------------------- Joey Dubs -------------------- 2000 Dakota - Bagged, Shaved, and more 2003 Ram - Fast, and perdy 1951 GMC Stepside - All apart, like a puzzle. |
