Old 02-20-2010, 11:05 AM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
What size are the trailing arm bolts? What needed for gas tank relocation
May be pulling my bed off today. Starting on gas tank relocation. Ima go into town and buy some bedliner to spray on my blazer tank.
1-what're all the ports on the tank for filler, ventline inlet for gas
2-is bedliner good for the tank? wipe with lauqer thiner and spray it on (rattle can).
3-Ima get some grade 8 bolts for trailing arm bushings. What size are they? I read somewhere that they're 5" 3/4" long whats the thred size? Ima also pick up new rearend gasket and figure out my gear ratio and change my oil back there. Already got paint/oven cleaner. What else for the job?
John
1999 Toyota Tacoma 4x4
Old 02-20-2010, 11:28 AM   #2
skeeterbug
skeeterbug's Avatar
Re: What size are the trailing arm bolts? What needed for gas tank relocation
you may want to check the condition of your bolts on the trailing arms, when i had mine off the bushings were shot but the bolts were in great shape they are really heavy duty bolts. just my 2 cents. i can measure the length on mine if you need me to my bed is still off the frame?
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 02-20-2010, 05:47 PM   #3
oldblue1968chevy
never mind guys thanks! any tips on removing old bushing (already got new ones )
John
Old 02-20-2010, 10:12 PM   #4
oldblue1968chevy
hey skeeterbug just noticed your from TN, where abouts is watertown? im in mcminnville TN(middle tn)
John
Old 02-20-2010, 10:51 PM   #5
skeeterbug
skeeterbug's Avatar
45 miles up I-40 east from nashville, just on the other side of lebanon look me up if your ever in the area.
2013 best 7.39
2014 best-7.38
Old 02-20-2010, 11:25 PM   #6
oldblue1968chevy
how far are ya from cookeville? im 1 hr south. cool
you dont know a guy with a red 67 step do ya? i bought some stuff from a guy up your way with a bunch of these trucks, the nicest being a red 67 step.
John
Old 02-20-2010, 11:35 PM   #7
skeeterbug
skeeterbug's Avatar
cookeville is about an hour on up 40 east from me, dont know anyone w/ red step.
2013 best 7.39
2014 best-7.38
