02-20-2010, 12:02 PM | #1 |
tires size suggestions
well guys i finally got some wheels on the way, 20 by 8.5 front and 22 by 9 rear coys. i have a 5,4 static drop on the truck right now just wondering what is the tallest sidewall height and section width i can get away with front and rear with such a minimal drop. i may bag it later on down the road just not right now.
2" drop springs fr, 3" drop spindles 4" drop springs rear
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage Last edited by skeeterbug; 02-20-2010 at 12:26 PM. Reason: drop corrections |
02-20-2010, 12:25 PM | #2 |
Happy to be here
Re: tires size suggestions
Why buy super tall tires if your thinking about bagging it? Even if you can't afford to bag it now, your probaly going to be happier if you get lower profile tires and drop it a bit more if needed.
02-20-2010, 12:29 PM | #3 |
good point i just dont want it to have alot of space between the top of the tires and the fenderwell lip, that looks kinda cheesy in my opinion.
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
02-20-2010, 12:37 PM | #4 |
I am running 255-40-20 on my 20x8.5 front wheels. I was running them with a 5" static drop before i went with bags and they looked good. I bagged my truck within a year so I'm glad I didn't go with bigger tires.
02-20-2010, 12:42 PM | #5 |
Happy to be here
If you go with a 255/40/20 or a 245/40/20 up front you might need a bit more drop, but I would give it a try. You might need to trim half a coil up front, but it doesn't sound like it.
02-20-2010, 12:43 PM | #6 |
thats kinda what i was thinking on the front, just wondering about the rear now. do you have any pics of your truck w/ static drop and the 255-40-20, i would love to see them.
02-20-2010, 12:56 PM | #7 |
here's 255-40's with 2.5" spindles and 2" springs.
02-20-2010, 01:07 PM | #8 |
you were right that looks really, really good thanks.
02-24-2010, 03:07 PM | #9 |
Squarebody Aficionado
nasty what size rim/tire is that in the back?
02-24-2010, 03:14 PM | #10 |
02-25-2010, 06:58 PM | #11 |
big guy
hey nasty do those big tires now fit with your air ride? (rear)
thanks Ray |
02-25-2010, 07:08 PM | #12 |
67-72 parts collector,…
The 22x9 Coys look good with a 265/35-22 or 285/35-22 tire.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-25-2010 at 07:13 PM. |
02-25-2010, 11:03 PM | #13 |
Happy to be here
Why yes, yes they do. That sits just right..
02-26-2010, 02:41 AM | #14 |
