Old 02-20-2010, 01:39 PM   #1
jrf790
rear brake problems
I am having problems bleeding the rear brakes, when I open the rear wheel cylinder, the pedal does not go to the floor. It does go to the floor for the front. I have replaced the wheel cylinders and still no luck. any Ideas?
jrf790 is offline   Reply With Quote
Old 02-20-2010, 01:56 PM   #2
NuBomb
NuBomb's Avatar
Re: rear brake problems
Maybe trash in the lines? Just taking a stab at it.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 02-20-2010, 08:08 PM   #3
70BLAZERX2
Stuck proportioning valve...Try bleeding it at the master cylinder 1st, then the pro. valve next...you may have to push on the rubber plunger on the end of the valve a few times...If you can,t get fluid there, you may have to change it out.
70BLAZERX2 is offline   Reply With Quote
