Original 307 Bellhousing Clutch Size 12"????
I have the original bell housing to my 1972 307. Can this fit a 12" clutch assay? I'm mating it to a gen IV 454. Are all the flywheels the same size and just the clutch sizes different?
Thanks, Dan |
#2 | |
Re: Original 307 Bellhousing Clutch Size 12"????
It depends on the 'wheel, some have both bolt-hole patterns, but I have seen them with only one. Bellhousing, I am not sure, but I would think so.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
I'm mostly concerned with the big block flywheel. I don't mind using a 10.4 or 11'' clutch/plate
sharp as a marble
![]() Join Date: Jan 2007
might need some help here? The flywheels on ALL chevys are either 153 tooth, or 168 tooth. The physical OD cannot be that much different I would think. SO, if I am correct the flywheel should fit??
that's kinda what i was thinking too and pretty much all 454 flywheels are 168.
My '72 was originally a 307, the bellhousing is the same one used on most / if not all manuals from 67-72 Cast #3925505. . . I currently have a 168 tooth flywheel with an 11" clutch. I was shopping for a new flywheel and clutch, and according to Summit I can put a 12" clutch under the bellhousing (As previously stated, depends on the flywheel holes.)
![]() 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! ![]() |
never finish start another
My 307 1969 with a three on the tree is an 11 inch 168 tooth. I am now running a Powerglide with a 153 tooth. All with the same housing. The holes on my original fly wheel are 12 1/2 inches. Help this helps. I don't see how a 12" will work with 12 1/2 holes in the flywheel.
I just put a 12" clutch on my 307 and everything bolts up great. it is the same clutch for the 454. Same splines and everything. go for it and have fun.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
See: I know nothing!
![]() Last edited by nplocoman; 02-20-2010 at 10:40 PM. |
Old School
If you have to change flywheels, be sure to get a 454 specific flywheel as they are externally balanced.
I just ordered the 12'' dual friction from centerforce with 26 spline input. We'll see how it works.
- Dan |
