02-20-2010, 06:27 PM | #1 |
69 project truck for sale, 454, and other parts
Update.... Well I thought you could email people via the site, if that's not the case, get me at mplex2000 at yahoo.com. THANKS!!!! *** Started life as a 69 C10 Step. Due to serious life changes I must sell. For details, see my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=361455 Cab was scrapped, this one is a factory ac, I have the original vin and title. LOTS of parts, including: ALL NEW suspension - ball joints, tie rods, cross shafts, springs, shocks, bushings, etc etc etc. 4" drop springs rear and 2.5" drop spindles in front. New front discs, new drum rears. Fresh rebuilt p/s pump. All new bolts, everywhere. Two axle housings and axle sets, one 6 and one 5 lug. Needs some body parts and trailing arms. Tons more parts come with this, a few body pieces including decent doors, factory A/C parts, gauge clusters, bench seat, radiator, new rad support, much more, lots of small parts. I have a good (38k mile) 454 and a th400 combo, selling separate, will deal if you want everything. I know I'm going to get it bad on this like anybody that sells an unfinished project...I'll ask $1500 without the engine and see what offers I get. Need to sell within the next few weeks if possible. I'd like to see $1500 out of the 454/400 combo. The engine has an edelbrock intake, new intake gaskets, new stainless bolt set, oil filter, 5qt oil, plugs, and a few other items. New Hedman 2" primary, 3" collector (ball/flange) headers for this truck/engine combo. $250 HEI dizzy with new cap, rotor, coil and good plug wires. $75 Holley (shiny silver) 750cfm vac sec with elec choke, prob needs a kit $100 Holley 650 DP, in pieces, with lots of new stuff (hardware kit, holley kit and more). Main body has some grinding or something done, not sure, but should be fine. Looks like they were removing the choke horn, etc. $100 Precision gear master gear set, 12 bolt truck, 3.73 gears with all the bearings and such. I have no clue what they sell for, asking $200?? Telstars, 15x7 front and 15x10 rear, decent tires, will put the offset and other details up later. Great shape, 15x7 are actually new never used wheels. Asking $600 Inline tube stainless brake line set, new $150 *SOLD* Cab corners (not needed for the current cab) $20 ea? New POL engine and trans mounts/crossmember. $150 New Energy Susp cab mount set $40 (red) Fresh rebuilt tilt column (yes, truck one) I looked where I bought it and the price is now 500 there, so I'll ask $400. Don't know if that's fair so make a reasonable offer if not. PLEASE EMAIL IF YOU'RE INTERESTED. I DON'T CHECK THE BOARD OFTEN. Last edited by mplex2000; 02-22-2010 at 11:15 PM. |
02-20-2010, 08:21 PM | #2 |
VA72C10
Re: 69 project truck for sale, 454, and other parts
great prices...sorry for the sale and bump for you.
Looking for a 67-72 swb or blazer project in or around VA. |
02-20-2010, 09:08 PM | #3 |
Can you tell me which inline tube kit you have?
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
02-20-2010, 11:45 PM | #4 |
No chance you have some good or new black carpet?
02-21-2010, 10:03 AM | #5 |
Dpottebaum
I assume this is an auto shift tilt column, but just making sure? Thanks.
02-21-2010, 11:11 AM | #6 |
If you separate the frame stuff - I would be interested in the 4" rear drop springs pending price and pix.
02-21-2010, 11:19 AM | #7 |
I'd like to be first in line for cab corners pending info on who they are made by.
Thanks! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-21-2010, 12:38 PM | #8 |
I'm interested in the suspension/frame if you will separate.also the inline tube lines.let me know.thanks
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
02-21-2010, 01:04 PM | #9 |
motor exploder
Put me first in line for the poly cab mount set! thanks.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-21-2010, 01:51 PM | #10 |
Active Member
If you diside to part thing . I may be intrested in the 2,5 drop spindles. Will e-mail you.
67 short step 71 Custom |
02-21-2010, 05:18 PM | #11 |
Gone Fishing
Interested in the brake line set from inline tube. Which part # is it. For disk or drums? Can pick up local
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
02-21-2010, 05:41 PM | #12 |
if bosshog passes on the polly cab-mounts ill take them, and im interested in the HEI pending on the price. thanks
02-21-2010, 06:01 PM | #13 |
Inline tube kit is, as stated, stainless, for a 69 short step.
No I don't have carpet. Yes, the column is auto shift. No, I won't sell the springs separate and I definitely don't want to go take pics of coil springs....they look like brand new coil springs Cab corners are goodmark I believe, bought from kennys trucks a few years ago. Make an offer on the frame and suspension, but it ain't getting much cheaper. We all know there is a LOT of money in this thing. BossHog, if you want them, email me. No, I don't want to part the drop spindles. At least you emailed though, you're the only one! Again, I really don't know what part number it is, but given the truck it was purchased for, one might deduce that the kit is for a 69 short step with disc/drum. Sorry, I threw the box away a couple years ago. c10seconds, whoever emails me first gets it. Again folks, not to be rude but lots of time is something I don't have right now. If you want something, email me. If you call it here, and somebody else emails me, you're going to miss out. THANKS! Last edited by mplex2000; 02-21-2010 at 06:03 PM. |
02-21-2010, 06:06 PM | #14 |
where is your email posted?
02-21-2010, 07:09 PM | #15 |
Still Learning
Intersted in the front suspension if you will seperate and pending price. Thanks
02-21-2010, 07:22 PM | #16 |
Emails sent.
02-22-2010, 03:23 AM | #17 |
resident oilfield trash
Are your headers shorty headers or long tube??? put me in line if they are shorties also are they coated
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada Last edited by jbristo67; 02-22-2010 at 03:24 AM. |
02-22-2010, 12:37 PM | #18 |
Gone Fishing
e-mail sent
02-22-2010, 01:03 PM | #19 |
I'm out on the frame and suspension.good luck on the sale.
02-22-2010, 02:37 PM | #20 |
I would like to purchase the Heater-A/C controller, if its available. PM sent.
02-22-2010, 02:40 PM | #21 |
GUYS, I'm not looking to part the truck out, I don't have time for that. Please read the post, if there is a separate price for something, that's it. Otherwise, I want to sell the majority of this together if possible.
02-22-2010, 03:22 PM | #22 |
motor exploder
email sent for cab mounts
02-26-2010, 01:38 AM | #23 |
motor exploder
Anybody heard anything? I sent and email, haven't heard back. I know mplex said he was busy, I justed wanted to check.
