Old 02-20-2010, 07:18 PM   #1
nibs
JRods Garage
nibs's Avatar
Cluster Bezel
Alright, I have seen this bezel on a couple trucks and I really want to know who makes it. Anyone have some input? I was gonna message the guy that I stole this pic from, but he hasnt been on since '08
Thanks guys
Or even this one...
nibs is offline   Reply With Quote
Old 02-20-2010, 07:35 PM   #2
1971ChevyTruck
1971ChevyTruck's Avatar
Re: Cluster Bezel
I am wondering the same thing!!
1971ChevyTruck is offline   Reply With Quote
Old 02-20-2010, 08:15 PM   #3
airdale94
airdale94's Avatar
Re: Cluster Bezel
Not the same but close. Member makes these.
http://67-72chevytrucks.com/vboard/s...d.php?t=252902
airdale94 is offline   Reply With Quote
Old 02-20-2010, 08:37 PM   #4
nibs
JRods Garage
nibs's Avatar
Re: Cluster Bezel
Found both!!!
http://www.carolinaclassictrucks.com...h-accents.html
Old 02-20-2010, 11:01 PM   #5
Fitz
Re: Cluster Bezel
There are two styles of that panel. One by Dolphin Instruments (http://www.dolphingauges.com) looks like the top picture. No Limit (http://www.nolimit.net) has the bottom panel which is a bit different but they also make a matching glove box door. Billet Barge here we come!
Fitz is offline   Reply With Quote
Old 02-21-2010, 03:13 AM   #6
mychebe
mychebe's Avatar
Re: Cluster Bezel
Hi you can find it in the Brothers catalog page 26
mychebe is offline   Reply With Quote
Old 02-21-2010, 03:42 AM   #7
hbaublit
hbaublit's Avatar
Re: Cluster Bezel
I found them for cheap, with no instruments, When I get home on Wednesday I will look and see what magazine it's in and a price.
hbaublit is offline   Reply With Quote
Old 02-21-2010, 06:14 AM   #8
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Cluster Bezel
I just finished installing the NoLimit cluster. For the money, it is really nice quality but not for the faint of heart. The gauges are not configured the same as a stock cluster so you have to cut out parts of the dash to install it. If you ever want to go back to stock, you're out of luck but if you want a nice quality piece, it is the nicest aluminum cluster out there IMHO.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-21-2010, 07:35 AM   #9
nibs
JRods Garage
nibs's Avatar
Re: Cluster Bezel
Sweet! Im looking forward to hearing from you.
Did you get any pics? Also, did you use your old gauge faces or use aftermarket?
Old 02-21-2010, 01:12 PM   #10
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Cluster Bezel
Stock gauges won't work... You can buy the bezel from NoLimit separately or complete with Autometer gauges (3 styles to choose from). I bought the complete kit because the price on the gauge kit was very reasonable (probably cheaper than you could buy them separately). Either way, it is designed to work with aftermarket gauges.
Sorry, I don't have any pics right now. It looks exactly like the one in the blue truck... If you need some I could try to snap a few next week.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 02-21-2010, 01:14 PM   #11
bigguy69
dazed and confused
bigguy69's Avatar
Re: Cluster Bezel
i like the way those look!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-21-2010, 02:29 PM   #12
mychebe
mychebe's Avatar
Re: Cluster Bezel
I think the No Limit bezel is better quality but the brothers bezel requires no cutting and if your going to paint it then the Brothers may be the choice.Any way happy hunting and after looking at the picture of the blue c10 I may rethink my options because that looks great.
Old 02-21-2010, 11:16 PM   #13
Brad
Out of the carpool lane.
Brad's Avatar
Re: Cluster Bezel
It's too bad No Limit just makes that panel with the ball end mill lines instead of just smooth. That's what I'd love to have.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-21-2010, 11:42 PM   #14
nibs
JRods Garage
nibs's Avatar
Re: Cluster Bezel
that is ideally what I want too, because I am going to end up painting it in the long run...
Old 02-24-2010, 12:35 AM   #15
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Cluster Bezel
Here are some pictures of the NoLimit cluster. I have to say, it is very nice quality but it will have taken me quite a bit of time to get it to fit the way I want. First, because the gauges fit so "snug" behind the cluster, the convex shape of the gauge bezel was preventing it from fitting flush against the back of the hole. I had to carefully (and I mean carefully) grind of the back edge of each hole with a die grinder to create a bevel and open it up to allow the gauge to site in the hole. Also, to install the unit, you have to cut away most of the top edge of the dash opening to the point where there isn't much left to mount to. This really isn't an issue as far as securing the cluster because it is solid aluminum but I am going to fabricate a piece of flat bar to mount across the top so that it snugs it up to the dash a little better. Keep in mind, I have been told by friends that I am anal about this stuff so what I deem to be a poor fit might be perfect for most everyone else.
Some advice, be careful with the finish... It came perfect from the Vendor but, because it is a mirror finish, it scratches very easily. Basically, if you look at it the wrong way, it will scratch. I put a coat of Zoops Seal on it so it is better protected now but still touchy. Also, if I did it again, I would fit it into the dash before installing the gauges... You quickly run out of room behind the cluster when all the gauges are in.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 02-24-2010, 01:28 AM   #16
mychebe
mychebe's Avatar
Re: Cluster Bezel
great job c10, it looks great,do you have a billet steering column as well?
Old 02-24-2010, 01:39 AM   #17
Nova70
Nova70's Avatar
Re: Cluster Bezel
Looks great C10. I was also wondering where I could find those, thanks for all the info even though I'm not O.P.
'70 K10-- 4" lift on 35"s-- For Sale
http://www.ksl.com/index.php?sid=733...iew&ad=4578305
Nova70 is offline   Reply With Quote
Old 02-24-2010, 02:25 AM   #18
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Cluster Bezel
My truck has been on the road for almost 2 years with a "stock" style interior... I was waiting for my buddy the "custom interior guy" to free up some time in his schedule to do my truck. I already had the black column in the truck and thought about swapping it but decided against it. There are a few other black "accents" like the door rubbers, some knobs, the stereo face, etc. so I decided to leave it and see how it looked. I do, however, have a Billet Specialties steering wheel going in. It is the Street Star wheel that matches my road wheels and we are going to wrap it with the same leather as the interior.
As I said before, if you are doing a custom interior, don't mind a bit of work to install it and want a high-quality bezel, I would recommend this one. I have been swearing at it a bit through the install process but I'm sure I will be happy with the end result.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 02-24-2010, 04:19 AM   #19
nibs
JRods Garage
nibs's Avatar
Re: Cluster Bezel
Hey, I really appreciate your pics and testimonial. It was just what I needed to make my mind on this purchase.
Old 02-24-2010, 01:07 PM   #20
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: Cluster Bezel
Here is the link to the Brother's billet bezel.
http://www.brotherstrucks.com/prodin...number=CGP6772
Pricey but nice quality.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
