Old 02-20-2010, 08:27 PM   #1
troy54gmc
troy54gmc's Avatar
Need HELP.. Rear axle info
Ok guys, I really need your help with this one. I bought what i think is a camaro rear axle today. I just need help determining if it is from a camaro, what year, and what type and gears. It has a really wierd front housing that i havent seen before (check picture) and came with a torsion or panhard bar setup on it. It does have disc brakes and the standard 5 on 4-3/4 lugs. Any info you guys have would help me out alot. Thanks....
troy54gmc is offline   Reply With Quote
Old 02-20-2010, 08:30 PM   #2
troy54gmc
troy54gmc's Avatar
Re: Need HELP.. Rear axle info
More pictures.
Old 02-20-2010, 09:35 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
2.34 posi 10 bolt. Camaro had a torque bar bolted on the front of the housing
dwcsr is offline   Reply With Quote
Old 02-20-2010, 09:45 PM   #4
Kabwe
Certified Car Nut
Kabwe's Avatar
That is a 7.5 10 bolt. I don't think those came with 2.34 gears, so I'm thinking that is 13:42 stamped on the ring gear (not 18:42) which would give you 3.23 gears which sound about right. But if that is 18:42 stamp on that ring gear I stand corrected. But thats a strange gear ratio to have with a later model 7.5 10 bolt.
Kabwe is offline   Reply With Quote
Old 02-21-2010, 01:35 AM   #5
troy54gmc
troy54gmc's Avatar
Hey kabwe, it is 13:42. thanks for the info. So you think its posi? it has a tab on it that says use limited slip oil only. 3.43. Where does the torque bar attach? ive never seen that before. Do you know where i can find a picture of one? do you guys know what year of camaro this is from? Thanks again guys for the info.
Old 02-21-2010, 02:35 AM   #6
Kabwe
Certified Car Nut
Kabwe's Avatar
Yes its posi (limited slip), and was in a 3rd Gen Camero year is 1988 through 1992. The tag says it has 3:43 gears, but the numbers on the ring gear indicates it's 3:23. 42 divided by 13 will give 3:23 gears. Its not a strong rear but if you are not building a powerful engine you should be okay. Sorry I don't have any pics of the rearend installed in its stocked form.
Old 02-21-2010, 12:47 PM   #7
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
The cast in bracket on the pinion housing part of the case.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
