02-20-2010, 10:59 PM | #1 |
Brake question
The passenger side front brake does not release? I replaced the caliper but it still does the same? Brakes are blead. It really gets hot from rubbing, what should we try next?
02-20-2010, 11:37 PM | #3 |
Re: Brake question
Thanks we will give it a try!!
02-20-2010, 11:51 PM | #4 |
Re: Brake question
If the rubber line was swelled shut would I be able to bleed the line?
02-21-2010, 12:04 AM | #6 |
Re: Brake question
also check your exhaust (headers) and brake lines. an exhaust leak could be aiming at the brake line and the heat it causing the fluid to expand and closing the caliper.
02-21-2010, 12:08 AM | #7 |
Re: Brake question
It was tough to compress piston back but fluid pushed out fine??
02-21-2010, 12:13 AM | #8 |
Badass
Re: Brake question
did you pump the brakes and bleed the brakes?
lift the front of the truck up,pump he brakes untill you got a hard pedel and go and spin the front wheels.if its hard to spin the wheel then its the line.
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
02-21-2010, 12:14 AM | #9 |
Robert Olson Transport
Re: Brake question
did you get a rebuilt caliper or a new one? some rebuilds can be bad out of the box if something hangs up, but my first guess would be the rubber line or a kink in the metal line.
02-21-2010, 12:15 AM | #10 |
Re: Brake question
Thats what I needed its the line!!!!!
