resident oilfield trash
Need a favor from one of you factory big block guys
I need one of you guys to measure from the front of your block to the radiator. I am trying to figure out clearances for my serpentine system. Thanks in advance guys
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() Last edited by jbristo67; 02-21-2010 at 04:24 AM. |
![]() Join Date: Aug 2004
Re: Need a favor from one of you factory big block guys
I've got about 10.5" from the rad surface to the water pump mating surface.
I unloaded a stock 89 BBC serp setup I was going to use because of the lack of space.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#3 | |
i jave a gen 5 big block. i also used the gen 5 serpentine. its a tight fit but it fits really good. this is retaining the mech fan. idk if that helps much
On my setup with the motor in the stock location, there was no room for the '89 mechanical fan, I think there was less than 1" of room between the waterpump hub and the rad. It would have been tight for a dual electric fan. In hindsight, I wish I would have kept it and maybe shifted the motor back an inch or so, or found a dual fan that would work.
