Old 02-21-2010, 04:17 PM   #1
C10Sim
C10Sim's Avatar
? to those who have installed a front roll pan
I believe that I have seen people chop the front tips of the frame in order to install a front roll pan. If this is correct, How much? I would like to do this if needed without install the entire front clip to find out.
Thanks,
Simon
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
Old 02-21-2010, 04:22 PM   #2
mbgmike
Re: ? to those who have installed a front roll pan
Thanks,
Simon
Yes you have to cut the horns off. its about 3.5 to 4 inches. I can get a better length but not now. Its just behind the first hole
mbgmike is offline   Reply With Quote
Old 02-21-2010, 08:41 PM   #3
midevil1
ShortBus KingPin
midevil1's Avatar
Maybe you can judge the amount from this pic. I will dig up somemore.
midevil1 is offline   Reply With Quote
Old 02-22-2010, 09:55 AM   #4
C10Sim
C10Sim's Avatar
If I could get the length from the radiator support bracket that would be great.
1968 Chevy Pickup
Old 02-22-2010, 10:10 AM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
save what you cut off, so you can weld back on if you change your mind later.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-22-2010, 11:44 AM   #6
cdowns
cdowns's Avatar
if you take the cutoffs and tackweld them inside the frame rail// nobody will see them and they wont get lost
Old 02-22-2010, 08:31 PM   #7
midevil1
ShortBus KingPin
midevil1's Avatar
I am in Utah right now but I could get you an exact measurement. If I recall it is about 2" in front of the radiator supports.
