Old 02-21-2010, 08:12 PM   #1
spinem
haha, ford guys...
stock psi for mech. fuel pump?
can some one tell me how many psi the stock mechanical fuel pump makes on a non computer controlled 1/2T 350?
spinem is offline   Reply With Quote
Old 02-21-2010, 08:20 PM   #2
cableguy0
Re: stock psi for mech. fuel pump?
They vary but it should between between 5-7 psi. some lower some higher.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-21-2010, 08:26 PM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-21-2010, 11:10 PM   #4
spinem
haha, ford guys...
really? i figured it to be higher? 7only huh?
Old 02-21-2010, 11:31 PM   #5
Restrorob
Restrorob's Avatar
Yep 7 lbs, That's the max pressure on the Demon carb sitting on my 502. Much over that will result in running rich/flooding.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-21-2010, 11:52 PM   #6
diponyou
diponyou's Avatar
yea yea we all know you got a sweet 502,you dont have to rub it in...
im just jealous
diponyou is offline   Reply With Quote
Old 02-22-2010, 12:06 AM   #7
Restrorob
Restrorob's Avatar
Sorry, I only mentioned it to use as reference to even a big block runs low fuel pressures as well.
If ya believe that one I'll tell ya another.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-22-2010, 12:24 AM   #8
diponyou
diponyou's Avatar
ahahahaha
Old 02-22-2010, 12:26 AM   #9
spinem
haha, ford guys...
awesome, thanks guys!
Old 02-22-2010, 09:44 AM   #10
cableguy0
The fuel pressure has nothing to do with the engine size. Carburetors cannot handle more than 7psi in most cases because it will push the needles off the seat and flood the carb. The only exception would be spring loaded needles and seats used in off road and race carbs but even they will get pushed open with fuel pressure too high. Edelbrocks are finnicky too they dont like more than 5.5psi or they will run rich at idle.
