Old 02-21-2010, 09:53 PM   #1
54Caddy
GM Addicted
54Caddy's Avatar
Lowered Sway Bar Mount??
I know they sell lowered sway bar mounts for lowered trucks for the 67-72s but do they have any for our trucks. These mounts are the front two on the frame they move the sway bar closer up to the frame, would help out from my sway bar rubbing.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-21-2010, 09:58 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lowered Sway Bar Mount??
You have two options to choose from. You can use the lowered sway bar mount from ECE, or you can bolt the bushing clamps directly to the frame. If your truck is mildly lowered, the lowered mounts will probably give you the best angle. If your really low or bagged, bolting directly to the frame may best fight your needs.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-21-2010, 10:19 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
thanks mine rite now its just mildly lowered but i will be lowering it more eventually or bag it. The mounts just rub on speed bumps, steep drive ways and parking stalls. Going to have to order me up a set thanks.
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 10:22 PM   #4
54Caddy
GM Addicted
54Caddy's Avatar
it shows those are for the earlier model trucks, theyll still bolt up?
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 10:34 PM   #5
3r!c84
Badass
3r!c84's Avatar
have you tryed going with a 3/4ton sway bar too?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-21-2010, 10:36 PM   #6
54Caddy
GM Addicted
54Caddy's Avatar
no isn't the 3/4 ton sway bar thicker?? It would handle better with that right, was also thinking of using 3/4 ton coils so its stiffer. I think it would handle a lot better
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 10:38 PM   #7
3r!c84
Badass
3r!c84's Avatar
yes its thicker,and the coils are thicker too.i want to do this swap on mine,,,ive hurd only good things about the thicker sway bar
-00 Saturn 5spd
1/4:13:90
Old 02-21-2010, 10:45 PM   #8
54Caddy
GM Addicted
54Caddy's Avatar
Alright looks like me and you have a race on who does it first ahahah. I will go look for the sway bar and springs soon. Hopefully find some for a decent price at good old pick and pull. I think it'll ride a lot better. I want to put a rear sway bar in mine also.
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 10:50 PM   #9
FLEET72
FLEET72's Avatar
Been on there for 10+ years. '72 stock ride height, planned on lowering but never got around to it.
You can see that bolting directly to the frame will buy another inch of clearance.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 02-21-2010, 10:52 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
alrite so the 67-72 mounts will work then looks like ill order my pair then.
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 11:09 PM   #11
3r!c84
Badass
3r!c84's Avatar
yeah im going out in a few weeks to look i need one for the back too.is there any stock trucks i can take them off to make them work? if u know
-00 Saturn 5spd
1/4:13:90
Old 02-21-2010, 11:10 PM   #12
54Caddy
GM Addicted
54Caddy's Avatar
I dont know i wish. I looked up some before there about 160 for the kit. Be nice if there was one that we could make fit. Anyone on here have this set up 3/4 ton sway bar, coils and a rear sway bar if so how does it ride??
..Mac’s Garage..
IG:MacsGarage
Old 02-21-2010, 11:21 PM   #13
pig rig
pig rig's Avatar
the sway bar off the 1ton camperspecial is bigger yet and for the rear the dually camper specials have a bolt on sway bar
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-21-2010, 11:23 PM   #14
joe231
joe231's Avatar
One other option is to mount you sway bar on top of the factory brackets.
I believe that will move the sway bar up 1 1/2-2", but you might have to remove at least one bracket to get the bar on top.
I didn't have the factory brackets, so I just mounted mine directly to the frame on my '80.
CHEVY ONLY
Old 02-22-2010, 12:30 AM   #15
spinem
haha, ford guys...
whats the down side of mounting the bushings directally to the frame?
spinem is offline   Reply With Quote
Old 02-22-2010, 01:56 AM   #16
54Caddy
GM Addicted
54Caddy's Avatar
so the rear of a dually will have the sway bar also or just the camper one??
..Mac’s Garage..
IG:MacsGarage
Old 02-22-2010, 07:42 AM   #17
3r!c84
Badass
3r!c84's Avatar
will it bolt up to my ten bolt?????
-00 Saturn 5spd
1/4:13:90
Old 02-22-2010, 08:28 AM   #18
joe231
joe231's Avatar
The only down side I see is drilling holes in the frame...
CHEVY ONLY
Old 02-23-2010, 12:27 AM   #19
ocbaud
Garage Queen Material
will this fit on our trucks?
ECE doesn't list it for us, but it LOOKS like it would work. if so, i'ma order it
also, whats everyone recommend for upgraded sway bars?
I've got a stock unit in the front and a hellwig in the rear(which is actually the same size as the front, hence having more oversteer than wanted)
ocbaud is offline   Reply With Quote
Old 02-23-2010, 12:47 AM   #20
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Everything that I have read on here about the rear sway bars from the Camper Special (hard to find trucks, at least here) is that they will pretty much just bolt on. May take a little adapting to your rear end, but seems to be straight forward.
I too have been looking for one to help mine stop handling like a soup bowl.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-23-2010, 01:19 AM   #21
54Caddy
GM Addicted
54Caddy's Avatar
so the camper specials have them on it?? If so after the first i will be getting one there are a few i know of.
..Mac’s Garage..
IG:MacsGarage
Old 02-23-2010, 01:26 AM   #22
Driveway Dreams
I have car A.D.D.
Yes. Camper Special trucks had the rear sway bars stock.
-Gerald
Old 02-23-2010, 01:41 AM   #23
54Caddy
GM Addicted
54Caddy's Avatar
alrite maybe ill grab a few and sell off the rest ah thats a good idea.
..Mac’s Garage..
IG:MacsGarage
