Old 02-22-2010, 12:26 AM   #1
Alex Hayley
oil pressure gauge fitting
Is there anyway to hook a braided stainless steel line to the oil pressure gauge fitting? Once the line adapter is removed from the engine by the distributor, it is a typical 1/8" NPT female. Is there any way to do something similar at the gauge?
Alex Hayley is offline   Reply With Quote
Old 02-22-2010, 04:09 PM   #2
FriscoDave
FriscoDave's Avatar
Re: oil pressure gauge fitting
Are you using the stock gauge or an aftermarket one?
FriscoDave is offline   Reply With Quote
Old 02-22-2010, 04:12 PM   #3
Alex Hayley
Stock gauge. It is the factory compression or nipple fitting.
Old 02-22-2010, 07:37 PM   #4
FriscoDave
FriscoDave's Avatar
This is what I used, but with an aftermarket gauge. Don't know if it will work
with an stock gauge. http://www.summitracing.com/parts/ATM-3227/
Old 02-22-2010, 08:46 PM   #5
Alex Hayley
I had looked at that kit but could not see how the fittings would work with the stock fitting on the gauge. Can anyone verify if this kit would work with the stock fitting on the oil pressure gauge?
Old 02-23-2010, 12:35 AM   #6
GASWAGON
AMERICAN IRON ADDICT
Autometer sells braided oil pressure line in different lengths. it will come with a 1/8 pipe to -4 line fitting and then it will come with some other fittings to cover the popular gauge fittings.
GASWAGON is offline   Reply With Quote
Old 02-23-2010, 01:38 AM   #7
Racinaround
Racinaround's Avatar
I going to watch this one!
I have $3000,00 of fittings on my wall and couldn't find one to work???
Im not giving up!
I was going to make a post about this, and hope someone knows
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 02-23-2010, 09:41 AM   #8
neba
the guage does have a fitting i havent seen before. i think you could leave a few inches of your old line and use a compression connector
neba is offline   Reply With Quote
Old 02-23-2010, 11:25 PM   #9
Alex Hayley
I might have to do that. I hope not though. I am going to be in Cleveland next week and will go down to Summit and take a look at the kits in person.
Old 02-25-2010, 07:14 PM   #10
FriscoDave
FriscoDave's Avatar
Maybe a combination of these two kits will work. http://www.summitracing.com/parts/VDO-150855/?rtype=10 http://www.summitracing.com/parts/ATM-3227/
Old 02-25-2010, 07:41 PM   #11
Thealien
Thealien's Avatar
The trucks have a fitting in the block that goes from 1/8 NPT to the factory flare/compression fitting. You could probably make a 1-2" piece of the copper line with the factory fittings on both ends. One end would go into the gauge and the other into the factory fitting that went into the block. You would now have a 1/8NPT female in the block and a male on the old fitting you took out of the block. From there you should be able to find adapter fittings to those braided lines. I would think you should be able to find the braided line with 1/8NPT on the ends but I didn't see any on summit?
This line should then work?
