02-22-2010, 09:49 AM | #1 |
Bearing Price
So I got an Eaton Rear end of sorts, has a bad pinion bearing.
I got one on order but ouch...246 dollars. It's a huge som-B, double roller bout 5 inches tall and a couple wide. Anyone know the one, are they pricey south of the 49th. Brian showed me around my Differential and all the good stuff I didn't know. Like the little oil grooves in the big crown gear that are still there. Say's it should work fine when he's done. He went and painted the case, doh. Now I'll have to do the rest. All bearings and races looked real sweet to me, but more important to him. It's got 456 gears. That should net me some good speed and MPG eh!! You Merican's whopped are Kanuk A$$es last night. Your goalie was on fire eh!! Good game tho, bad outcome if your me Last edited by driftbuster; 02-22-2010 at 10:02 AM. |
02-22-2010, 05:01 PM | #2 |
Re: Bearing Price
Don,
Holy cow that's expensive! Available at my local NAPA parts store as shown below. I probably need one too, since there was one in the glovebox when I got the truck. Pinion Bearing - Rear Axle Product Line: NAPA Bearings Comments: w/ H052, H072 Axles;Rear Per Car Qty.: 1 Compare BRG M5205UV Price Unit : : 56.99 Each |
02-23-2010, 12:30 AM | #3 | |
60-66 Nut
Re: Bearing Price
I'm afraind that that's the other pinion bearing......the smaller cheaper one. Here is the one that driftbuster is needing and it's more $$ at NAPA here in the states.
http://www.napaonline.com/Search/Det...+50014+2014028 I had to buy one of these bearings 20+ years ago. Regular price was around $120 then but I was able to get it for about $90 with my good buddy discount. Quote:
02-23-2010, 01:45 AM | #4 | |
Re: Bearing Price
ron check out the link; http://www.google.ca/search?hl=en&so...tryCA&aq=f&oq= Last edited by padresag; 02-23-2010 at 02:12 AM. |
02-23-2010, 08:42 AM | #5 |
Re: Bearing Price
that's thru CBS my price (Canadian Bearing Supply). I get all
my bearings, seals circlips there. Buddy said he had only 2 sources for it. One in USA was 250 USD's plus shipping. One in Kanukastan is cheaper but the place only ships to Brantford twice a month free and I just missed the last order of course thanks Last edited by driftbuster; 02-23-2010 at 08:42 AM. |
