Stereo install in 79
I did a quick search but did not find what I was looking for. I have a CD/Stereo head unit that I would like to install. Since the dash is designed for the old 'post' style radios, what is the best way to install a rectangular unit in the stock location? Are there kits available or does everyone just 'roll their own'? Any suggestions for cutting the panel ?
Thanks Steve
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
Re: Stereo install in 79
alot of peolple just cut the dash to fit the stereo. There is not acual intal kit cause the hole is not large enough. iether that or you can mount it else were suck as the glove box or make a custom enclosure for it under the dash. Just make sure the hole it just a hair bigger than the actual cd player so you can fit the battle cage in there. ( the metal cage that holds the cd player)
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
>130dB Moderator
Be a man and cut it.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Ya thats the only way to do it MAN UP CUT IT UP
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." |
Look on crutchfield site they have a plate for it.Use the plate to mark your cut and go to town.
I figured I would have to cut the dash. I just wanted to see if anyone had any tips-n-tricks I could follow before I 'mangled' it on my own. I have to find a radio install kit with a 'battle cage'. I pulled the radio out of a Corolla that I'm selling (put the stock radio back in) but it does not have the cage.
Is it better to get the panel from someplace like Crutchfield or can you cut the bezel also?
Cruzzzn' Vet
Man I can't believe what i'm seeing, Cut It!!!
#9 | |
1962 C-10
Be a man, and go without CD's! ![]() ![]() ![]()
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
>130dB Moderator
Only problem is its always the same tune and all you can change is the volume...
haha, ford guys...
switch the factory ac controlls /w/ the old radio slot (oooh now the gears are turning)
#12 | |
Chevys Kick A$$
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Last edited by Hoods69BadBowTie; 03-19-2010 at 05:51 PM. |
