Old 02-22-2010, 12:24 PM   #1
asickber
tune-up problem
My truck was due for a little work so I replaced the fuel lines/filters, plugs/wires, fixed an exhaust leak, and changed the oil. It runs much better when it's warmed up, but when first started it runs very rough. It seems to be getting enough gas, but the engine really shakes the truck. Also when I give it gas the lights get brighter and when I let off they get more dim. Is that normal?
Any advice on what to look at first?
asickber is offline   Reply With Quote
Old 02-22-2010, 12:28 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: tune-up problem
make sure you have the plug wires in the right firing order
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-22-2010, 01:21 PM   #3
asickber
Re: tune-up problem
I didn't check the order to start with but I had been running the truck for years on the order it's on and it idled ok. When I replaced them I did them one at a time to not confuse any. I'll double check when I get home. I also gapped the plugs.
Old 02-22-2010, 01:26 PM   #4
cdowns
cdowns's Avatar
Re: tune-up problem
points or hei dizzy? different plug gaps for the two//if points did you set dwell? have you checked for bad vaccume hoses?
lights getting brighter is normal
Old 02-22-2010, 01:48 PM   #5
asickber
Re: tune-up problem
Points. I didn't adjust the dwell and never have. Can I simply adjust it by trial and error and see if it runs better? I haven't checked the vacuum hoses so I'll look into that too.
Old 02-22-2010, 01:55 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
Re: tune-up problem
Can't run points and not adjust the dwell.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-22-2010, 02:05 PM   #7
asickber
Re: tune-up problem
When does the dwell need adjusted? I didn't change the points. Do you adjust it everytime you put new plugs in?
Old 02-22-2010, 03:57 PM   #8
cdowns
cdowns's Avatar
Re: tune-up problem
every 5000 miles is a good interval for checking cleaning and adjusting points
Old 02-22-2010, 06:29 PM   #9
umwtnt
umwtnt's Avatar
Re: tune-up problem
I have also purchased new plugs that were bad from the factory. Just a thought. Good Luck.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 02-22-2010, 07:13 PM   #10
Wrenchbender Ret
Re: tune-up problem
If you set the point gap with a feeler gauge the dwell will be in limits.
Wrenchbender Ret is offline   Reply With Quote
Old 02-22-2010, 09:12 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: tune-up problem
I would start with replacing the points and doing all the BS that goes along.
Actually, I'd start with an HEI swap.
Old 02-22-2010, 09:17 PM   #12
coloradosean2009
coloradosean2009's Avatar
Re: tune-up problem
x2. any other effort or $ spent is a waste of time
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
