Old 02-22-2010, 01:24 PM   #1
72K20
Slow Old Timer
Coil Spring Dimensions?
I have a new (to me) 72 C10 Stepper. Either the PO may have lowered (or should I say attempted), how can I verify? What should the dimensions of the front and rear coils be? Any approximate height numbers would be greatly appreciated. My plan is to install 2.5 drop spindles and 4 in rear lowering springs but I really want to know what is (or isn't) in there now???
72K20 is offline   Reply With Quote
Old 02-22-2010, 03:33 PM   #2
dfwright
dfwright's Avatar
Re: Coil Spring Dimensions?
Here's a link to an older thread on the same subject -- there's some measurements in there:
how long are factory springs???
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-22-2010, 04:48 PM   #3
72K20
Slow Old Timer
Thanks for the lead! I obviously need to learn how to use the "Search" function better!!!
Old 02-22-2010, 05:10 PM   #4
dfwright
dfwright's Avatar
I'm not sure I could have found it if I hadn't already known about it
It's not always easy to figure out the exact right terms to search for.
