02-22-2010, 03:27 PM | #1 |
'67 Ignition Switch
So my ignition switch needs replacing and I was wondering if I could use a switch from a later model with the ACC position?
Also, can I use the tumblers from my current switch on the later switch? Thanks! |
02-22-2010, 06:21 PM | #2 | |
The Older Generation
Re: '67 Ignition Switch
Yes, '68-'72, but your wire loom and plugin won't have the wire for the acc position. The lock cylinder is the same but you will have to use the chrome bezel and spacer from your current switch. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-22-2010 at 06:23 PM. |
