Old 02-22-2010, 06:37 PM   #1
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Question Doing alot of upgrades
Hello, I am doing alot of upgrades to my '69 and wanted to see if I should post it as a partial build or what. I am taking pictures as I go. Here is a list of some upgrades I'm doing; 1- Tilt column install. 2- Brake booster, prop valve, master cylinder from CPP install. 3- Upgrading my dash gauges and panel. 4- Upgrading the top end of my big block, intake, carb, valve covers, dist, plugs and wires. 5- Doing some dress up on my under dash wiring. I have taken some pictures before I started and taking pictures as I go. I thought if I posted it I could get opinions, advise and HELP LOL from our great members. I love this forum and I value every members opinions, comments etc... Thank you.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-22-2010, 07:16 PM   #2
silverstreak
Re: Doing alot of upgrades
I look forward to following the upgrades. A moderator may chime in later and suggest the best way to post it.
silverstreak is offline   Reply With Quote
Old 02-22-2010, 07:49 PM   #3
Camaro_nut2001
Great, thank you
Old 02-23-2010, 10:01 AM   #4
Camaro_nut2001
I don't know what to do here. Do I just start posting pictures and details or what. Is any of our members even interested in this upgrade project I'm doing?
Old 02-23-2010, 10:44 AM   #5
jaymc32
Yes, we are. I enjoy reading the build threads!
jaymc32 is offline   Reply With Quote
Old 02-23-2010, 11:18 AM   #6
dan42
dan42's Avatar
Sure, just start posting 'em. Nothing like pictures to get guys to comment.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-23-2010, 11:41 AM   #7
Camaro_nut2001
Ok, here are some pictures of before I start the upgrades.Name:  steering wheel.jpg
Name:  old gauges.jpg
Name:  dash before.jpg
Size:  53.3 KB. I am going to try to do the classic rod type look.
Old 02-23-2010, 11:54 AM   #8
Camaro_nut2001
I am doing the top end and front of my engine as well so here are some pictures before I start it.Name:  Power Steering Pump.jpg
Name:  alt setup.jpg
Name:  DSide engine.jpg
Name:  left side pullys.jpg
Name:  PSide engine.jpg
Old 02-23-2010, 12:06 PM   #9
Camaro_nut2001
Here are a few with the column out. If you do a column swap remember to take the bolt completely out where your column connects to the shaft as there is an indention in the column spline that the bolt rests in. Also, when you take the steering wheel off also take the column shift arm off as it will be in the way when you remove your column.Name:  Column Out Firewall.jpg
Name:  column out inside.jpg
Name:  Old Column Out.jpg
Old 02-23-2010, 12:14 PM   #10
Camaro_nut2001
And some with the dash cluster out. I forgot to add one of the inside with the column out so I added it to these. I am going to take some much better pictures of everything out and the wiring.Name:  cluster out.jpg
Name:  brake pedal.jpg
Name:  dash wiring.jpg
Old 02-23-2010, 12:19 PM   #11
Camaro_nut2001
My brake booster assembly that I bought from CPP is suppose to be here the 26th of this month. I'm gonna tell you fellers, that Jeff at CPP is a super nice guy and has went out of his way to help me. More pictures coming soon.
Old 02-23-2010, 12:21 PM   #12
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Exactly! Full Build Thread, Partial Build Thread...it doesn't matter. Start posting the pics and update us as you go along.
Just my $0.02 here, I would start a full build thread, in the projects and builds section. That way you and we can keep track of your progress.
Good luck and keep up posted. Nice truck!
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 02-23-2010, 12:46 PM   #13
Camaro_nut2001
How do I move this to the build section? Thank you for the compliment on my truck.
Old 02-23-2010, 12:50 PM   #14
wancosc356
wancosc356's Avatar
You could have a mod move it there,
Or you could just start a new thread there. Just copy and past your pictures and what not. By starting a new one, you could create a build thread title that reflects your truck...i.e name of your truck or build plans.
No problem!
Michael
Old 02-23-2010, 01:40 PM   #15
Camaro_nut2001
Ok thanks, I will PM a mod. and see if they can move it.
Old 02-24-2010, 10:59 PM   #16
Camaro_nut2001
Well I was up until 1:45am this morning looking at different gauges and sizes and PRICES for my dash cluster. I thought I would go ahead and build the cluster until my brake booster assembly gets here, it is on time and suppose to be at my house on the 26th. I don't want to put the new tilt in before I do the booster as it is alot easier to get the bolt out of the brake pedal with the column out, lol.
So, back to my gauges. After I found what I wanted in the bottom four gauges and the speedometer and tach, added it all up, I fell out of my computer chair and hurt my left arm. Man those gauges are costly. I slept on it last night and woke up with an idea.
Big 18 wheeler trucks have alot of gauges and for the most part they would work in my truck. I went down the road a piece to a salvage yard of big trucks. Long story short, here's what I came home with. Here are a few pictures.Name:  new gauges.jpg
Name:  new gauges1.jpg
Name:  new gauges2.jpg
Name:  center gauge.jpg
Size:  66.5 KB I really wanted white faced gauges but no luck. The middle 3 3/8 hole with the truck tach in it is going to be a surprise for you guys and gals. It might be a tach and it might not. Now I have to come up with my Speedometer & Tach. I know it's not the high dollar Dolphin gauges but for what I've got in them and finding something I can work with for the middle 3 3/8 hole I'm satisfied. Matter of fact, I'm Happy.
Old 02-24-2010, 11:06 PM   #17
silverstreak
Actually, they look pretty cool. Did you get the sensors to go with them? I don't think the diesel tach will work too well though.
Old 02-24-2010, 11:31 PM   #18
Camaro_nut2001
LOL, nope it won't I just got it to fill in that middle hole but I have a few different ideas and the good part is it lights up. As far as the senders I'm just gonna have to buy the temp sender as the oil pressure gauge is mechanical and the temp gauge i'm running now is mechanical. Thank you for the compliment.
Old 02-27-2010, 06:51 PM   #19
Camaro_nut2001
Hello fellow members, my brake booster assembly came in yesterday and it is better quality than I ever thought it would be. Here is a picture fresh out of the box-Attachment 553090. After reading through some of the information on it I was impressed. I took it out and dry fit it to make sure everything was correct. Good to go. I then disassembeled and preped and started the primer and paint-Attachment 553091
Attachment 553092
Attachment 553093Here is a picture of the four bottom gauges installed in the panel. I got my speedometer and tach ordered but they won't be here untill the middle of the week and I am waiting on one piece for my invention on the center hole, should get here in a couple more days and I can finish the cluster up. I also finished cleaning up the under dash wiring after replacing a few wires that were spliced and in bad shape. Here are the last batch of pictures for now-Name:  lower gauges in.jpg
Name:  dash wiring cleaned up.jpg
Old 02-27-2010, 06:55 PM   #20
Camaro_nut2001
I don't know what happened, the first batch of pictures didn't post. Let's try again Name:  new booster assembly.jpg
Name:  partial booster painted.jpg
Name:  partial mas cyl painted.jpg
Old 02-27-2010, 11:00 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good and nice progress!
Where did you pick up your new gauge bezel?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-28-2010, 04:10 AM   #22
Camaro_nut2001
Hello, I want to say LMC but I'm not really positive on that. I've got stuff from alot of different places it's hard to remember.
Old 03-01-2010, 08:10 PM   #23
Camaro_nut2001
Thumbs up Re: Doing alot of upgrades
Name:  side water pump.jpg
Size:  51.7 KBHey fellers and gals, I've been playing around a little bit and wanted to show a little progress. Here is what I saw when I removed the boosterAttachment 554145.
After cleaning with brake clean and then thinner I got it to look a little betterAttachment 554145
I finally got that bulky alternater bracket gone, here is the setup that was on it and with it gone and it will stay gone. That bypass hose was fun getting off, lol Name:  PSide engine.jpg
Old 03-01-2010, 08:15 PM   #24
Camaro_nut2001
Now keep in mind this was all the P/O had done to the truck. Here is the throttle rod and it worked great but it won't be going back on.Name:  old throttle rod.jpg
Old 03-01-2010, 08:21 PM   #25
Camaro_nut2001
Dang my firewall pictures didn't post and there was a picture with the wiring tied up, lets try it again.Name:  booster out.jpg
Name:  painted firewall.jpg
Name:  tied wiring.jpg
