Old 02-22-2010, 09:06 PM   #1
zephyr
Red face Need some advice on engine swap!
I have a 72 4x4 with a v-8. The distributor is set against the fire wall.It was orginally a 6 cylinder. Do I need to change the crossmember to get the motor more forward? What all do I need to change to get it right?:
zephyr is offline   Reply With Quote
Old 02-22-2010, 09:19 PM   #2
fishingjred73
fishingjred73's Avatar
Re: Need some advice on engine swap!
You just need the v-8 motor stands. They bolt in a set of holes in the front of the cross member. If you do a search on here you can find some pics that show exactly where they go.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 02-22-2010, 09:36 PM   #3
fishingjred73
Your 6 cyl stands will work this just shows why the engine is sitting so close to the firewall. Post #2 picture #3 http://67-72chevytrucks.com/vboard/s...d.php?t=375443
James
Member of
Old 02-22-2010, 10:43 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
He has a 4x4. The link posted above is for 2wd trucks.
His truck is set up properly. Small blocks in 4x4 trucks sit further back than 2wd trucks do.
Old 02-22-2010, 10:57 PM   #5
fishingjred73
Didn't even notice 4x4 sorry.
James
Member of
Old 02-23-2010, 12:18 AM   #6
cdowns
cdowns's Avatar
if you think it's to tight massage firewall with BFH
Old 02-23-2010, 12:24 AM   #7
blazin
i haad the same problem with my blazer when i pulled the v6. when i first put the new 383 engine in the distributor cap broke when i gave it some gas. i had to pull the engine forward just to put a new/smaller distributor in.. and if i ever have any problems with this one i will have to do the same thing. i was thinking about putting a one inch lift in. dont know what else to do.
blazin is offline   Reply With Quote
