Old 02-22-2010, 09:37 PM   #1
eastcoastcivil
Question 3/4 Ton Rear End Help Please
Can somebody check out this link and tell me if this would fit my 67 C20?
I see the brackets on the axle but don't think it is a trailing arm set up like my C20.
http://moncton.kijiji.ca/c-cars-vehi...AdIdZ178399214
If your not living for something, your dieing for nothing...
eastcoastcivil is offline   Reply With Quote
Old 02-22-2010, 10:39 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 3/4 Ton Rear End Help Please
That's not a coil spring rearend. It's out of a later leaf spring truck.
Old 02-22-2010, 11:15 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
Not a bolt in, but if you have any fab skills, $30-40 for new perch mounts depending whom you order from, access to a welder and understand how to degree a rear end, you can make this work. dont forget that you may need to either get a new driveshaft or using a different rear ujoint to make this work as well.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
