haha, ford guys...
Cooling can? cooling frame rail radiator? Any hp gains??
Re: Any one running a fuel cooler?
i am actually running one, its just a trans cooler though, using it for fuel, during the summer i'd be cruising and all of a sudden my truck would die, well the heat would cause a vapor lock in between the fuel pressure regulator and carb (i have no clue why) so i had to have a flat head in the glove comp to get out and bleed the fuel system, well i threw this on there to see if it helped and i never had the problem again!
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
Gettin It One Pice At A Time
Huh! Never heard of this. Subscribing
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
haha, ford guys...
Cool stuff, thinking about trying the can design... well... making one. ![]() |
BAD BOW-Silverado XST
One shot, one kill.
The "can" design was intended to be filled with ice. I used one on my 69 Chevelle for drag raceing. For street use just use the finned little radiators designed for this purpose.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
i like i like must see a pic when you get this done spinem
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." |
#8 | |
haha, ford guys...
will do! i just cant figure out how to make a spiral of tube /w/ 2 long sides to protrude out of the can like jegs brand does.... (wont fit in can)... i need to do some more sketching. here in the valley 120F summers are sure hot... especially /w/ a 350F block 2 inches from the fuel lines. Last edited by spinem; 02-23-2010 at 06:44 PM. |
