02-23-2010, 03:39 PM | #1 |
What would you do?
How would you replace the seal lip? would you use a strip of metal? or is there a piece that I can buy as a replacement? Thanks Guys
02-23-2010, 03:53 PM | #2 |
Re: What would you do?
that strip is part of the kick panal blew and the floor panel above
02-23-2010, 03:55 PM | #3 |
http://www.truckandcarshop.com/trucks60_72/t60_068.html Bottom left had side.. Rocker panels.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-23-2010, 04:00 PM | #4 |
Ive used a few different patch panels and I would suggest that you use the TRI PLUS patch panels. The reason I say that is because they tend to fit more to the Stock sheet metal than other that I have used. Im sure someone will disagree but that is what I have found to work the best for me. Take a close look at the sheet metal where it goes just past that Seal Strip in the cab, you might find that you need to replace the inside rocker as well. Good luck with your Project.
JRBECK64 |
02-23-2010, 04:48 PM | #5 |
SIR
wire brush that part get it clean and THEN decide what your going to do,if the rust isn't too bad just weld it up and grind it down....
66long low fleet http://community.webshots.com/user/LVNR66 |
03-12-2010, 02:17 AM | #6 |
you know thats right
