Old 02-23-2010, 09:35 PM   #1
J/D/S
gas mileage
Here's the deal, I want a big block in my 79 short bed I like the way it fills the engine bay up but I want to know what kind of gas mileage I can get? Here's the combo I'm looking to run, a carburated stock 396 or 454 a 700R4 and 308 gears what do you think it will get guys? And please just answer my question no flaming or dumb a$$ remarks.
John Bernard Books (The Shootist):
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them."
J/D/S is offline   Reply With Quote
Old 02-23-2010, 10:01 PM   #2
Matt Man
Matt Man's Avatar
Re: gas mileage
from what i have read you can not see past 12mpg in a big block period. i get about 10. but your truck is lighter so maybe u can see a bit better than 12. how tall of a tire with those 3:08's?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 02-23-2010, 10:07 PM   #3
J/D/S
Re: gas mileage
I was thinking of putting 20" rims on her
Old 02-23-2010, 10:09 PM   #4
Benelli
Watchin the rust grow
Benelli's Avatar
Re: gas mileage
I suggest going with 3.42 gears. I think that it would let the motor be under less load, which could use less gas. Then again, I'm not sure on the difference between a SB and a BB.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-23-2010, 10:35 PM   #5
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: gas mileage
With the 700 and a 336 or a 342 gear you could get in the low teens. A 308 is too high in my opinion in overdrive. It all depends on the cam selection and the other specs of the big block. My TBI 454/400 only gets around 6\7 in town with short tires and a 308. I am pulling it out for a 5.3\4l60E combo. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-23-2010, 10:39 PM   #6
spinem
haha, ford guys...
Re: gas mileage
yyuck yyuck iz a big block!!! no good gas milage!! yuck. oh sorry, no smart a$$...
11 keeping with trafic in town. 14hw....15/w/ the motor off rolling downhill (couldent help it)
spinem is offline   Reply With Quote
Old 02-25-2010, 05:02 PM   #7
J/D/S
Re: gas mileage
Why 342 gears? they'll make the engine work harder then 308's
Old 02-25-2010, 10:02 PM   #8
Big Port Jimmy 6
Addicted to Rust
Re: gas mileage
With an over drive the 3:42 gears are actually 2.39 in over drive the 308s are 2.15. The 342 will also help you come off the light a little easier. I usually like a 3:73 (2.61) with the overdrives, but with the torque of the big block you will be ok a little taller gear. Jay
Current trucks:
Old 02-25-2010, 10:03 PM   #9
munger
munger's Avatar
Re: gas mileage
342s will keep the motor in a sweet spot where it will pull good in od and get good mileage 308s will just lugg it causing worse gas mileage and no power at all in od
mitch
87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s
munger is offline   Reply With Quote
Old 02-25-2010, 10:49 PM   #10
J/D/S
Re: gas mileage
So what will the final ratio work out to with 20" rims and 308's. And can anyone tell me what the cruising RPM of a stock big block is at 75 MPH with a 700R4 and low gears like 342 or lower
Old 02-25-2010, 11:03 PM   #11
Raised On Chevy!
Raised On Chevy!'s Avatar
Re: gas mileage
The size of the rim isn't what you really need to know, it's the over all size of the rear tires, that will tell what you need for gears. As for the big block thing, if your looking for milage your looking at the wrong engine!
Raised On Chevy! is offline   Reply With Quote
Old 02-25-2010, 11:10 PM   #12
kenm78
Broken Down
kenm78's Avatar
Re: gas mileage
You didn't say what side tire you wanted just wheel, Assuming your stock tire is a 235/75/R15 which most 1/2 tons were. I figured using a 275/40R20 tire you get a final drive of around 2.16:1
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 02-26-2010, 09:49 AM   #13
longbedrick
longbedrick's Avatar
Re: gas mileage
back when the '73 LWB was my daily driver I was getting about 7mpg. I was getting about 10 after a full tune up with a rebuilt HEI distributor and newer tires. My dad's old fuel injected 454 dually got about 10mpg
longbedrick is offline   Reply With Quote
Old 02-26-2010, 10:07 AM   #14
larrystone
larrystone's Avatar
Re: gas mileage
My 1992 came with the 700r4, 4.3 tbi and 3.08 rear.
When it was new I got 25 mpg with a 500 pound motorcycle in an open bed.
If you want gas mileage with acceptable power I suggest you pull a 4.3 with the fancy fuel injection and the computer from a wrecked small S-10 Chevy Blazer.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
Old 02-26-2010, 10:55 AM   #15
grinch4om
dang its hot
grinch4om's Avatar
Re: gas mileage
I get 13-14 on the highway...10-12 in town, warmer weather the in town improves a tad
grinch4om is offline   Reply With Quote
