Old 02-23-2010, 09:56 PM   #1
71longbed-brew
71longbed-brew's Avatar
summit headers
Are they any good .. would i be better off buying another brand ?
350/th350
Sportsman2 heads
Performer Intake
1406 carb
3.42 Eaton Posi
71longbed-brew is offline   Reply With Quote
Old 02-23-2010, 10:26 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: summit headers
free bump id be interested also, usually sumit brand is acually a brand stuffed in a white box marketd 'summit'.
John
1999 Toyota Tacoma 4x4
Old 02-23-2010, 11:08 PM   #3
spinem
haha, ford guys...
Re: summit headers
passenger side must be dented to clear frame. they will tell you other wise.. they lie. i used a pipe and a hammer..... eventually the torque of the motor will make room. i doubt it really effects performance.... this was on my 71gmc
spinem is offline   Reply With Quote
Old 02-23-2010, 11:10 PM   #4
packers05
Re: summit headers
I am running a cheap set of summits on my 72 blazer and installing A set of coated summits on a 72 gmc k-10 customer truck so far so good cant beat the price!
packers05 is offline   Reply With Quote
Old 02-24-2010, 12:11 AM   #5
Bpokey
Bpokey's Avatar
Re: summit headers
I bought a set of hedman elite coated headers from a place called street side auto for $260 shipped. They seem to have sales going on all the time and I got free shipping. I haven't installed them yet but they look really good.
Bpokey is offline   Reply With Quote
Old 02-24-2010, 02:27 AM   #6
Stano
Stano's Avatar
Re: summit headers
I have summit brand headers on my 67 and my dad bought a set of flowtechs from autozone for his they are the same... identical if you will. So for what its worth no problems out of either set. Mine are 9 years old his are 6 or so. These are the painted variety btw.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 02-24-2010, 03:45 AM   #7
Blackbird66
Re: summit headers
Running summit brand since '02 on 2wd manual. No clearance problems at all, not even with the stock " z" bar clutch linkage. I did not need to dent mine to clear the frame. They have held up quite well, why spend more money?
Blackbird66 is offline   Reply With Quote
Old 02-24-2010, 06:04 AM   #8
67chevemall
67chevemall's Avatar
Re: summit headers
Yep when mine finally rust through I am going with the summitt headers too..
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-24-2010, 07:56 AM   #9
eagleuh1
eagleuh1's Avatar
Re: summit headers
I ran a set of flowtechs on mine. Fit couldn't have been any better. No interference anywhere. Had to modify my AC bracket buy cutting part off because it mounted over exhaust manifold. Also new Alt. brackets because mounted to front of exhaust manifolds. This is on a 68 C20 with 327, no holes in front of heads for bracket mounting. Installed from bottom, didn't have to remove anything, didn't even have to raise truck. It's a c20. Good luck with the install. Go with Copper gaskets though.
eagleuh1 is offline   Reply With Quote
Old 02-24-2010, 07:58 AM   #10
Beuford
Beuford's Avatar
Re: summit headers
I have a set of Summit headers on my `70 C-20.I had no issues with frame interference or otherwise.I'm running a hyd clutch so can't vouch for manual linkage clearance,but it looks like there should be clearance. I bought the painted ones for $99.00 since I don't drive mine in the salt in winter.
Bob
Beuford is offline   Reply With Quote
Old 02-24-2010, 08:18 AM   #11
kacz81
kacz81's Avatar
Re: summit headers
I bought a set of the "summit headers" 5 years ago and have had no problems with them i belive they came with all hadware/gaskets too and if remember they're made by pacesetter/monza there logo is stamped on the headers
kacz81 is offline   Reply With Quote
Old 02-24-2010, 08:31 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: summit headers
I speak from personal experience. Mine fit fine, I didn't have to modify any tubes.
Before I installed them, I noticed a part number stamped into the tube near the collectors on the bottom. Google search of that part number brought up Dynomax's webpage for GM truck headers. They are Dynomax headers.
Old 02-24-2010, 11:21 AM   #13
CARR33
Re: summit headers
All i can say about hedder purchases is to watch the tightness of the bends where they come out of the heads. I bought a 67 1/2 ton last week. I was running poorly ( choke wasnt opening all the way. Carb needed adj. And vac adv was hooked to manifold vac not ported from the carb ). After this i went to install new plugs and had to get four accell shorty plugs for hedder clearance. These arent cheap. A real shame cause the hedders are ceramic coated, and there was no reason to bend them this tight.
CARR33 is offline   Reply With Quote
Old 02-24-2010, 11:20 PM   #14
mas09ts
mas09ts's Avatar
Re: summit headers
Here's mine guys the 99$ pair came with hardware and gaskets. And as stated above fit great. Here's some pics.
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 02-24-2010, 11:39 PM   #15
'72customdeluxe
Re: summit headers
To the op, they are the same as flowtechs. On my lwb I didn't have to clearance the flowtechs. Small block.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-03-2010, 01:14 PM   #16
milner
milner's Avatar
Re: summit headers
I believe the summit headers have only a 1 1/2" primary.
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
Old 04-03-2010, 04:57 PM   #17
'72customdeluxe
Re: summit headers
THats correct, perfect for boosting torque on stock to mild sbc's. Stock manifolds only have a 2" outlet altogether..
