Old 02-23-2010, 10:17 PM   #1
ah_5500
Rear end swap
I have a 67 burb and a 67 shortbed both v8. I might be trading the burb off so I want to take the spool out of it since it's posi and swap it with the ring in my shortbed. Will this work? Same case? Would i have to change the pinion? Thanks fellas.
ah_5500 is offline   Reply With Quote
Old 02-23-2010, 11:13 PM   #2
harshard
Re: Rear end swap
If you are going to that much trouble to swap the 3rd member why not swap the pinion. I am not a 100% sure, but I would keep the ring gear and the pinion that were matched together, together if at all possible. If both ring gears are 8.75'' you should not have a problem. Sorry for the edit did not understand question at first. Shawn
harshard is offline   Reply With Quote
Old 02-23-2010, 11:39 PM   #3
chopped68
Re: Rear end swap
the ring and pinion must both be swapped together because they have 'meshed' otherwise they will destroy each other. just like when a flat tappet cam is changed,the lifters have to be changed also. hope i have been
some help to you.
ken
chopped68 is offline   Reply With Quote
Old 02-23-2010, 11:47 PM   #4
ah_5500
Re: Rear end swap
Big help. Didn't even think about them meshing to each other. I guess i may just swap the whole axle.
Old 02-24-2010, 12:46 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Rear end swap
that is the best idea, there is alot more to setting up a ring and pinion then you think. I can swap motors and trannys no problem, but when I tried a ring and pinion swap on a ranger I used to have it ended having too tight of clearance and sheared off the carrier at the side bearing. from then on I decided to leave that to the pros.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-24-2010, 08:39 PM   #6
ah_5500
Re: Rear end swap
yeah thats kinda what the old man said. guys ill snag me a axle from PAP or something
