02-23-2010, 10:43 PM | #1 |
1971 Chev 1/2 T 4wd with 454-exhaust manifolds?
Hello, I am looking for any suggestions re exhaust manifold or headers to fit this application. I've had Hooker Super Comps on before, but they are pricey. I think I've found some Hedmans that will work. However, I would prefer to use stock manifolds. Found some on a 402 in a '71 GMC that should work, but my engine sits lower so they won't clear the frame or the clutch linkage. Any ideas out there? thanks, Monte
02-23-2010, 11:52 PM | #2 |
Designated Grumpy Old Man
Re: 1971 Chev 1/2 T 4wd with 454-exhaust manifolds?
Moving this to the 67-72 truck forum so you can get more responses.
Oh by the way welcome aboard.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg Last edited by oldiron; 02-23-2010 at 11:53 PM. |
02-24-2010, 12:30 AM | #3 |
SWB 4x4 Collector
Normally on Big Block conversions for 4x4's, you need to notch/grind the frame to fit exhaust. They never made factory big block 4x4's for our years, so fitting them is custom work. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-24-2010, 12:50 AM | #4 |
Roadtrip!
When i did the swap in my 70, i used 1977 454 pickup exhaust manifolds. I had to grind one nub off the pass side manifold was it. Just dumb luck they worked that good. I did the swap probably 16 years ago...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-25-2010, 12:12 AM | #5 |
Thanks everyone for your quick, and great, replies! That is good info. I'm very impressed and happy with my first attempt on this forum. Monte
02-25-2010, 01:11 AM | #6 |
I built it
my 454 went in with no mods. (cept re-routing the exhaust to bolt up) i used the stock manifolds and the small block motor mounts and crossmember.
oh and welcome!!
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs Last edited by 72chevyk10; 02-25-2010 at 01:12 AM. |
