Old 02-23-2010, 11:33 PM   #1
richlandborn
richlandborn's Avatar
1958 3/4 ton and 1959 1/2 ton
Okay long description so stick with me. I bought a 1959 Apache 1/5 ton and planned on restoring and have come across a gutted 1958 3/4 ton 4x4. So now I have purchased the 58 and I am going to yank the motor and trans from my 59. With the 4wd can I attach a transfer case to the automatic transmission that is 2wd now? If so How? The engine and tranny are a 76 Chevy 350 and TH350 trans. Also The data plate from the 58 is missing is there a way to get a new data plate with a serial number? Thats all I can think of for now I got a million quastions floating around in my head though.......TBC wayne.westover@gmail.com
richlandborn is offline   Reply With Quote
Old 02-23-2010, 11:50 PM   #2
winchster
winchster's Avatar
Re: 1958 3/4 ton and 1959 1/2 ton
Yes and no. You have to change the output shaft on the transmission.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 02-24-2010, 02:32 PM   #3
OrrieG
OrrieG's Avatar
Do some searching in the 4x4 section here. Depending on the transfer type (NP203 vs NP205 probably) you will need to make sure you get the right spline configuration. for the trans and transfercase. Also different tranfer/trans combinations have differnt crossmember mount housings sometimes between the trans and transfercase (np203) or direct connection with mount on the transfer case (NP205). As said the output shaft and housing is different on 2wd and 4wd. To add to the confusion the transfer cases were used on other makes (Ford, Dodge) with different combinations to. Look at my build thread I am using a TH350/NP203 out of a 1974 K10 pickup in at 59 using the 59 frame and springs.
OrrieG is offline   Reply With Quote
Old 02-24-2010, 04:07 PM   #4
63 & 64 Bowties
and a few others
http://cgi.ebay.com/ebaymotors/CHEVR...item3efd17957d
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-25-2010, 09:54 PM   #5
richlandborn
Ok, Thanks for the good information. After I pick up my tahoe wich blew the diffirential in it from pulling the 58' in Breckenridge Im headed out to the local pick and pull to see what i can scavenge up maybe something good hopefully
Old 02-28-2010, 10:49 PM   #6
richlandborn
Can I take all the 4wd stuff off of the 3/4 ton and put it on my 1/2 frame. Soemone hacked up the 3/4 ton front end so I dont think I should use it now.
Thanks,
Wayne
