Old 02-24-2010, 01:16 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
72 Chevy C-10,LWB Drive line help, Please
I got the bed off to start rockers and cab corners when I realized the carrier bearing was shot. Whats the procedure for getting that bearing off the forward shaft?I get my service manual at the end of the week but have a new bearing assembly.Im just not sure how it comes off the shaft. Thanks!
Ironangel is offline   Reply With Quote
Old 02-24-2010, 03:29 AM   #2
airdale94
airdale94's Avatar
Re: 72 Chevy C-10,LWB Drive line help, Please
They're a press fit. Although not that close if it's rusted on there it could give you some trouble. You could try heating it. Or if you have a press. Or take it to a machine shop.
airdale94 is offline   Reply With Quote
Old 02-24-2010, 04:28 AM   #3
Jeffs70
Jeffs70's Avatar
to take the carrier bearing off, you need to take the center u-joint off from the clips then there is a bolt behind that you should pull and slide the yolk out then the bearing will slip off. I have never had one pressed on. but It might be pressed in there but I would try to pull the u-joint and yolk off first and see what you get into. easier then going to a machine shop and paying when you really dont need too spend the money for something simple
Jeffs70 is offline   Reply With Quote
Old 02-24-2010, 04:37 AM   #4
vegaschevy
I have done 3 in the past 6 weeks and every single on has been pressed on. Pull them off with a puller, and every new one did nto slide right on the shaft you had to press it on... which is the only way the bearing is going to work. So they have to be a press fit
vegaschevy is offline   Reply With Quote
Old 02-24-2010, 08:12 AM   #5
eagleuh1
eagleuh1's Avatar
Doing mine right now. easist way IMO is drop the 4 bolts holding carrier bearing on frame. Seperate the back shaft from front by sliding the yokes apart. Pull front shaft out of tranny. Have pan ready for fluid. You have to seperate 2 halves of housing. Then press or pull slinger/ bearing retainer off then press bearing off the shaft. It helps to soak it with some CRS or rust penetrant over night. They are pressed on At least for a 68 C20. Also, where can you buy a new Carrier bearing exactly like the old. NAPA has some strange looking crap that requires you make a spacer for the mount.
eagleuh1 is offline   Reply With Quote
Old 02-24-2010, 11:10 AM   #6
Ironangel
Ironangel's Avatar
Thanks for the responses you guys! I was surprised to find that the old auto parts/machine shop had the carrier bearing on the shelf! Its exactly like the stock bearing and only cost $12! I live in a small farming town in Nebraska and the auto parts store is still a mom and pop owned buisiness. The nearest NAPA is 25 miles away and the nearest city is 100 miles away, I like it like that! Ill be back with more questions and I sure thank you guys for the help! Michael Hill is "Ironangel"
Old 02-24-2010, 09:31 PM   #7
Ironangel
Ironangel's Avatar
Piece of cake! I soaked it in Kroil over night and it came apart with just a little persuasion and 1/2 NF bolt and thrust washer "presses" it on the last 1/4" or so. Thanks for the help all of you! Brakes are next,I get them tomorrow.
Old 02-24-2010, 09:37 PM   #8
LMN8UR
LMN8UR's Avatar
Make sure you mark the two shafts so they go back together the same as they were. I had a vibration problem when I put them together 180 degrees out. I didn't think it would matter, but my new bearing only lasted about 6 months. It's been 4 years on my third bearing, and all's happy!
Good Luck!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 02-28-2010, 08:45 PM   #9
Reefmonster
Is the bolt that holds yolk on Reverse thread??? I am having a hell of a time breaking mine loose, I actually broke my vice trying to get it loose.
Reefmonster is offline   Reply With Quote
Old 03-02-2010, 11:36 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
all carrier bearings are a press fit, if the old one slides off, the weld in stub needs to be replaced. also if the bolt on yoke has any play in it, both the yoke and stub need to be replaced.
dont put your driveshaft in a vice, dont beat on your driveshaft in a vice, dont crush your yoke when installing or removing ujoints.
if i had to remove a carrier bearing at home i would cut it off, as it is typical for them to be quite stubborn to remove. even when using tools designed for driveline work it is possible to damage a shaft by the forces required to remove a carrier bearing in 1 piece.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-04-2010, 08:48 AM   #11
Jeffs70
Jeffs70's Avatar
well hmmm mine wasnt pressed on tight enough to use a puller. now its making me wonder if something was wrong.
Old 03-04-2010, 09:51 AM   #12
Ironangel
Ironangel's Avatar
No, Its right hand thread.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Old 03-04-2010, 09:57 AM   #13
Ironangel
Ironangel's Avatar
As long as there is no free play between the spline stub and bearing your fine. Your just lucky thats all.
"Two Seventy Two's"
02 3/4 ton Express
Old 03-04-2010, 10:01 AM   #14
Monte Carlo Man
When my carrier bearing went bad, it also took out the dust shield on the end of the drive shaft. Does anyone know where you can get a new dust shield?
I believe that it was welded to the end of the drive shaft.
To take mine apart, I took both of the universals out and I removed the bolt from the end and then I put a pry bar in both ends and I chained it to a tree and I used a come along to pull the yoke off the end of the drive shaft.
Because the carrier bearing was completely gone, all I had to do was take the remaining part of the bearing off and slide on the new bearing. But because the dust shield was gone, it didn't last very long.
$12 is cheap, I think I paid $40 for one 25 years ago.
Monte Carlo Man is offline   Reply With Quote
Old 03-04-2010, 10:29 AM   #15
Ironangel
Ironangel's Avatar
I appreciate the input bradman but my manual describes and illistrates the use of a vise and where to strike the yoke with a hammer to either spread or close yoke tollorance for the u-joint snap rings. The removabe yokes retaining bolt is a 1/2" NF grade 5 bolt with a thrust washer that pushes the the yoke and the bearing back into their original position.
"Two Seventy Two's"
02 3/4 ton Express
Old 03-04-2010, 10:51 AM   #16
hayhauler71
hayhauler71's Avatar
http://www.iedls.com/bearings.html If you want a heavy duty bearing or do not want to do the job again I recommend one like this.
hayhauler71 is offline   Reply With Quote
Old 03-04-2010, 02:27 PM   #17
Ironangel
Ironangel's Avatar
Cool site,Thanks Hayhauler. You too LMN8UR,although Ive already made that mistake :sad: Its a fifty/fifty chance at this point. I do plan on having the shafts balanced soon. Heres something I read on a very small piece of paper in the new bearing box;It said to fill the rubber isolater with grease? Has anybody done this, and how???
"Two Seventy Two's"
02 3/4 ton Express
Old 03-04-2010, 02:31 PM   #18
Ironangel
Ironangel's Avatar
Im not sure what dust shield your talking about unless its the pinion shaft shield?
"Two Seventy Two's"
02 3/4 ton Express
Old 03-04-2010, 03:04 PM   #19
hayhauler71
I believe there was 2 dust shields. You would slide on the dust shield than the bearing than the other dust shield but when the bearing goes out the shields get destroyed.
Old 03-04-2010, 08:19 PM   #20
Jeffs70
Jeffs70's Avatar
OH man yes I do agree, Do not purchase a cheap bearing, I had this problem with my 72 a few years ago and It just kept going bad at least every few months. Best to get a good bearing and pay for one rather then a bunch of crap thats not worth waisting your time on.
Old 03-04-2010, 08:21 PM   #21
Jeffs70
Jeffs70's Avatar
Ok awesome Thank you that makes me feel better and not so worried now lol.
Old 03-04-2010, 10:09 PM   #22
brad_man_72
the boat guy
carrier bearings will last a long time when the shafts are in good condition and ballanced. even the cheap ones.
dust shields are completely not needed.
i spend about 40 hours a week building and repairing driveshafts for anything from hydrostatic kohler lawnmowers to ride the ducks amphibious vehicles.
Old 03-04-2010, 11:21 PM   #23
crushermechanic
crushermechanic's Avatar
before you install the bearing weld the edges of the top flange to the lower. it is just held by spot welds. i had 2 break there before i welded mine and they were spicer bearings.
crushermechanic is offline   Reply With Quote
