Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-24-2010, 11:07 AM   #1
53GMC
53GMC's Avatar
Idling issues?
Hey everyone....
my 1996 S10 4x4 vortec V6 needs a diagnosis....
when i first crank the truck up, it runs great (idles around 1000 RPM). If i horse the motor just a little, when i let off the gas it idles back around 1000RPM but will dip up and down from 1000 to around 750.
Any ideas what this could be caused from?
I have already changed the throttle/idle regulator out but it continues....
help?
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 02-25-2010, 09:11 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: Idling issues?
do you mean the Idle Air Control valve?
what you have is at first a high idle and then a hunting idle. both signs of a vacuum leak.
does the cruise control, heater mode selector (floor defrost vent function), 4x4 work correct? chase the hoses using the sticker on the fan shroud as a reference.
you could also have a leak where the plastic upper manifold meets the lower.
without a smoke machine it is gonna be hard to find.
you would need a scan tool to watch the fuel trims in order to do the carb cleaner thing.
if the hoses turn out OK you may consider just going ahead and doing the upper plenum gasket set. it's not too spendy or tough. Fel-Pro MS95816 is about $35-40 list. use ALL the parts included. do not skip the throttle body gasket.
68C15 is offline   Reply With Quote
Old 02-25-2010, 09:27 AM   #3
53GMC
53GMC's Avatar
Re: Idling issues?
Thank you 68C15,
I will chase some hoses and see if i cannot find a leak somewhere - hopefully ill be able to.
I was told that the part i replaced was called a throttle regulator sensor....is that different from the idle air control valve? if it is different i will probably try to replace it...
1953 GMC/S 10 Swap
