Old 02-24-2010, 11:16 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
72 Chevy C-10, Drive Shaft Conversion?
Howdy all, What is needed to install a one piece drive shaft? Ill be keeping the 350 sb below 400hp and using a turbo 350 tranny. Any hints or ideas? Thanks!
Ironangel is offline   Reply With Quote
Old 02-24-2010, 11:31 AM   #2
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Re: 72 Chevy C-10, Drive Shaft Conversion?
I know it really can't be done unless the truck is either lowered or you will have to chop that crossmemebr where the carrieir bearing bolts too. bobbo has a one piece in his and i think he has a 4 inch drop, i will be doing the same with my 69.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 02-24-2010, 01:04 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That is incorrect. I have had plenty of these trucks with 1 pieces driveshafts and not lowered. You just can't use one of those big 4 inch diameter shafts like late model trucks use.
Old 02-24-2010, 01:39 PM   #4
Ironangel
Ironangel's Avatar
I wonder if a fella Plated/beefed-up and cut out the bottom of the cross member opening to allow maximum clearance for the shaft? I kinda like those 4-5"dia. aluminium shafts........doable?
Old 02-24-2010, 02:31 PM   #5
Tx Firefighter
Seems like a reasonable idea if you wanted to do the work.
Old 02-24-2010, 06:22 PM   #6
57larry
I used a 1 piece driveshaft from a S10, don't remember what yr
57larry is offline   Reply With Quote
Old 02-24-2010, 06:44 PM   #7
big_al_71
big_al_71's Avatar
I also have a one piece in my truck with a 406hp close to 500 hp and a turbo 350 lowered six inches. I did trim the center support where the old two piece used to go thru. I went to a place named "miami driveline" the man asked me to measure the lenght between the tail housing and the differential and he asked horsepower,torque. He built me a driveshaft and he guaranteed me that it will hold up to 1000 hp guaranteed. He only charged me $250.00 if I remember correctly. It has been there for a year and 1/2 with zero issues...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-24-2010, 06:58 PM   #8
grs
My 69 is lowered 4 inches in the rear. I put a 3 inch, one piece drive shaft in it.
I had to take out the bracket that the carrier bearing bolted to. I removed the rivets, removed the bracket, and saved it.
grs is offline   Reply With Quote
Old 02-24-2010, 10:25 PM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
i built bobbos 1 piece driveshaft, and 3, 1 piece driveshafts for my 67. im pretty sure they are all 3" in diameter
as long as you dont have any clearance issues its not a problem. a few of these trucks came w 1 piece driveshafts from the factory.
any reason for switching to a 1 piece driveshaft?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-24-2010, 10:27 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
are we talking a short wheel base, or a long one?
On a LWB, I would stick with the 2 piece, it's stronger and more versitile.
Old 02-25-2010, 03:49 PM   #11
brothers69c-10
Suburban Hick
I agree that a two piece is more versatile, but how in the world is it stronger, have you seen the size of those carrier bearings?! Just one more thing to put stress on.
Another thought yeah you can have a 5 inch diameter driveshaft but if the wall of the tube is only a 1/16 of an inch thick not doing you much good. Look at alot of the new 3/4 and 1 ton trucks and compare the diameter of those tubes with a 1/2 ton. Generally they are smaller, but have alot thicker tube wall.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 02-25-2010, 06:37 PM   #12
grs
I had a one piece drive shaft made. I was told that the wall thickness was smaller then the 2 piece. But the one piece was stronger.
Old 02-25-2010, 10:53 PM   #13
Ironangel
Ironangel's Avatar
Im sticking with the two piece for now. The truck is a LWB C-10 with a stock 2bbl 350sb. I was wondering and thinking that a one piece shaft would be stronger and deliver a direct connect without torquing the grommet around the carrier bearing. Does anyone fill the rubber grommet with grease? I found a piece of paper instructing to do so. Do you "inject" the grease with a needle tip on the grease gun? Thanks for the comments and input keep them coming!
