Old 02-24-2010, 01:06 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
from mechanical clutch to Hydraulic
i would like to have Hydraulic operated clutch isnted of the mechanical thats all messed up on my truck what do i need to do this swap
if anyone have ever done this swap pics if possible
Thanks Thomas
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 02-24-2010, 05:33 PM   #2
Drzronnie
Re: from mechanical clutch to Hydraulic
That seems like a pretty difficult job. I would imagine you would have to change the clutch fork and make mounts for a slave cylinder. You might have to change the pedal too. What is wrong with your clutch now that would make you look into that much work?
82 C60
82 C20 (neverending project)
77 Mercedes 300D (gets me to work)
Drzronnie is offline   Reply With Quote
Old 02-24-2010, 05:59 PM   #3
rcbildr
rcbildr's Avatar
If you want to go the "easy" route find an 85 and up chevy truck/blazer/suburban and pull the parts off of it...IIRC 85 is when they went to hydraulic clutch. You will need the Bellousing, Clutch Fork, slave cylinder, master cylinder, and the pedal bracket that goes under the dash. I've heard getting the hydraulics bled properly can be a PITA.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-25-2010, 01:20 AM   #4
GmtGmt
GmtGmt's Avatar
its all messed up along home made parts
looks like i have to keep my mechanical oh well
Thomas
Old 02-25-2010, 05:24 PM   #5
rcbildr
rcbildr's Avatar
I sent you a pm.
My Projects:
1978 Camaro Z28
