Old 02-24-2010, 07:07 PM   #1
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Replacing rear coils
I'm going to replace my rear coils and would like step by step instructions. Any help is greatly appreciated.
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 02-24-2010, 07:16 PM   #2
cparman
sharp as a marble
Re: Replacing rear coils
It is pretty straight forward, actually. You need to get rear of the truck jacked up, and have jack stands under the frame rails in front of the rear end. Then do one spring R&R at a time. There is a long bolt that runs through the coil spring, at the top and bottom of the spring. The tough part, IMO, is getting those 40 yr old bolts to come loose. If you have an 1/2 air gun, it will be a big help, but even with that they might not come loose.
Jack up the rear end just until it move up a bit. This will compress the coil spring. Get the bolts out, and the slowly let the jack down until you can remove the spring. Put the new spring in and reverse the procedure.
Rear springs are not like fronts, in respect to how much the springs are compressed. Go slowly, pay attention, make sure that the jack stands are stable. HAVE FUN!
cparman is offline   Reply With Quote
Old 02-24-2010, 07:31 PM   #3
Piece of Work
Cultural Infidel
Thank you.
Fun isn't what comes to mind when dealing with old bolts and heated springs.
posted via La-Z-Boy
-Mark
Old 02-24-2010, 08:24 PM   #4
cparman
sharp as a marble
NOW, you have already got a bad attitude about the fun you will have!!! Dirt is my younger brother, and this repair/fun stuff, is all what you make it.
Do you have a torch available?
Do you have a lift available? Makes this a ton easier.
It is really not that bad, if you have a friend that will help you.
I replaced my OE springs a few months ago, and we had my truck up on a lift, and a box end wrench, 1/2 impact, a little bit of skin, and WA LA!!!! The damned spring almost mashed my big toe. On the right foot, the left foot is already FUBAR, and I did not need any more trama to it.
If you do not have a torch available, I might suggest that you soak the bolts with PB BLASTER, a day our so before the big event.
I am 54 yrs old, and STILL get excited when I think thru a project, and it turns out like I wanted to. I will tell you though, I ALWAYS have a plan B. Meaning that I have thought about what might happen that I cannot control
I LIKE A PLAN B PLAN !
pm me if you have a question
Old 02-24-2010, 08:42 PM   #5
Piece of Work
Cultural Infidel
I'm 49, will be doing this alone, in my driveway, no torch, no friends.
I do have a shiny new impact wrench! Of course it will be fun, when I'm finished. I am a big believer of planning and plan "b"s. As soon as this rain passes I'll get to work.
posted via La-Z-Boy
-Mark
Old 02-24-2010, 09:30 PM   #6
LMN8UR
LMN8UR's Avatar
Maybe a day or two before you start, spray the bolts a couple times with penetrating oil. You might also have a four foot cheater bar and a can of spinach available!
Good Luck!
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 02-24-2010, 09:45 PM   #7
vegaschevy
Heres a little better info on easy wasy... the EASY button.. LOL
jack stand the frame like mentioned. High enough that you can get an impact wrench under the trailing arm.
put a jack under the pumpkin or whatever side you are removing first. Jack it up to relieve a little pressure and remove the bottom bolt. Then lower the rear end and youll have more room to get to the top bolt! repeat for the other side.
vegaschevy is offline   Reply With Quote
Old 02-24-2010, 10:12 PM   #8
CWS
I am a rookie at working on these trucks, so my approach might be completely wrong. I was able to get the lower bolts loose without much effort. The upper bolts were not going to move, they were rusted together. I went and picked up a 4 and ½ inch grinder and a few flapper disc’s. (The disc’s run about $6 at Home Depot). Using the grinder, I just ground the head off the upper bolt and punched it through the frame. Once the bolt was punched into the frame, it was easy to get the remains out of the frame. Again I am a rookie, it took about 45 minutes to get the first upper bolt out and about 15 minutes to get the second upper bolt out on the other side of the truck. I replaced the bolts with grade 8 bolts I picked up at the local Ace Hardware.
Craig
CWS is offline   Reply With Quote
Old 02-24-2010, 10:26 PM   #9
LMN8UR
LMN8UR's Avatar
Craig
CWS - Sounds like you bypassed all the fun. As any PRO will tell you, to do this job properly you have to get rust in your eyes and at least three skinned knuckles.
Old 02-24-2010, 10:49 PM   #10
bigguy69
dazed and confused
bigguy69's Avatar
amen brother!!!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-24-2010, 11:57 PM   #11
nplocoman
never finish start another
nplocoman's Avatar
I just removed mine last night. I do have the bed off. The bottoms came off with the rattle gun. On the tops I used a breaker bar on the bottom with a box end on top. With a few turns both top bolts twisted in two. Soft bolts on mine. I am sure they are orginal.
nplocoman is offline   Reply With Quote
Old 02-25-2010, 11:21 AM   #12
Jblackie47803
The upper bolts on mine had long ago become one with the frame. I cut them completely out and used a C-notch kit to provide a new mounting hole for the bolt even though I probably could have gotten away without the kit from a clearance standpoint.
Jblackie47803 is offline   Reply With Quote
Old 02-25-2010, 11:36 AM   #13
bruceman1968
bruceman1968's Avatar
Mark, I to live in clearwater, that means you got a friend you don't even know about. I do construction work for a living. I can rebuild a sbc1 with confidence and supension work doesn't scare me so if you want some help let me know.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 02-25-2010, 11:44 AM   #14
Burb
Coordinator of Synchronicity
Burb's Avatar
See thats what this site is all about bringing people and trucks together
See you got friends in Clearwater.
Good luck guys.
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 02-25-2010, 02:25 PM   #15
mrein3
mrein3's Avatar
You guys in the desert are cute. Where metal rusts you never remove extra bolts because you can't just take it off, do your work and put it back.
You first try to take it off, bust a knuckle.
Strip the head, bust another knuckle.
Heat it up, start a fire.
You get the picture.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-25-2010, 02:31 PM   #16
lks dcvn
lks dcvn's Avatar
All the bolts I have to 'remove' up here in the MidWest means get the cut off wheel ready-
lks dcvn is offline   Reply With Quote
Old 02-25-2010, 06:56 PM   #17
cparman
sharp as a marble
I like it!! And the soak the bolts for a few days
heres a little better info on easy wasy... The easy button.. Lol
Put a jack under the pumpkin or whatever side you are removing first. Jack it up to relieve a little pressure and remove the bottom bolt. Then lower the rear end and youll have more room to get to the top bolt! Repeat for the other side.
Old 03-01-2010, 09:43 PM   #18
Piece of Work
Cultural Infidel
Thanks for all the info. Springs are replaced, no rust in my eyes and no skinned knuckles. The bottom bolts came out easily. The top bolts twisted in half.
The new springs have a 4" drop. The old springs had been heated. Why people heat and ruin there coils I will never understand.
posted via La-Z-Boy
-Mark
Old 03-02-2010, 10:13 AM   #19
I_FLY_LOW
Good Luck!
Bingo... I just did mine....
Wear some safety glasses/goggles, too... rust and dirt falling in the eyes, and filthy hands don't play well with each other...
I used Deep Creep on all the fasteners a half hour or so beforehand (while I changed my oil, and some other things...), and a 1/2" breaker bar, to get them started, then switched to a rachet, and took my time...
The really fun part is if, or when, you replace the front springs...
I tried to do them by myself...
came apart no problem.. trying to put them back in, eh, not so much...
You'll need a vict, er I mean friend to assist in that one...
At least I did...
Relax, take your time...
It's nasty, not exactly easy, but hey, you're workin on your truck...
Getting things done...
Have fun!
I_FLY_LOW is offline   Reply With Quote
